Activity Forums Adobe Encore DVD Unkown Error in Encore
  • Unkown Error in Encore
    Posted by Joe Bandy on January 10, 2009 at 6:20 am
    I was trying to build a disc in Encore CS3 today and got this message
    Unknown Error -12004. I called Adobe and spent 2 ½ hours on the phone with two different technicians trying to solve the problem. After all that time they had to tell me that they would need to call me back because they had no solution. I’m using a single timeline with a couple different video files. The main video is a M2V file and the others are MPEG 2. For Some reason I can build a project with 1 of each of the files on the timeline but not both.
    I can’t be the only person who has encountered this problem here’s what I’m using.
    The M2Vs use these settings
    I’m filming in 720P 29.97 drop frame to m2t files
    Editing in Adobe premiere CS3 and exporting to SD using these settings
    MPEG-DVD
    720 x 480 4:3
    Export Video and Audio
    Quality High (5)
    CBR 8mbps
    Progressive fields
    Audio: 16Bit 48 kHz
    The MPEG 2s use these settings only used for intros and credits
    720×480
    6000 kbps
    Interlaced field order B
    Joe Bandy replied 17 years, 7 months ago 2 Members · 2 Replies
  • Jeff Bellune
    January 10, 2009 at 2:28 pm
    Ruud Blauw provided an excellent answer in the Adobe U2U forum topic that you started. Do let us know here as well if his suggestions worked.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Joe Bandy
    January 17, 2009 at 8:06 am
    Yes it seems that making the switch from PCM to Dolby worked or has worked so far. I haven’t had the error since but now I have a new issue.
    Thanks for Your help!
