Activity Forums Apple Final Cut Pro Legacy Unknown FIle
  • Posted by Sebastian Swallow on March 9, 2009 at 8:16 am
    Hello,
    I have a DVD that I need to cut in Final Cut Pro. I used a program called Hand Brake to rip the DVD and create an .mov, when I open it in Quicktime Pro it says under format, Apple Mpeg4 Decompressor. Whenever I drag this .mov into final cut I get the fiollowing, “File Error, Unknown File”
    If I go, File>Import>files I get, “File Error: 1 file(s) recognised, 0 access denied, 1 unknown”
    I converted this to a pro res file using quicktime pro and it went from being 902MB to 18.41GB and when I try and bring the prores file into Final Cut it gives me the same warnings.
    Can anyone help?
    Sebastian Swallow replied 17 years, 6 months ago 2 Members · 3 Replies
  • Sebastian Swallow
    March 9, 2009 at 8:52 am
    I just converted the quicktime to a Photo Jpg mov and also a DVC pro NTSC .mov and it does the same thing when I try to import it.
  • Zane Barker
    March 9, 2009 at 3:37 pm
    https://forums.creativecow.net/faq/applefinalcutpro#40
    Pulling video from a DVD comes up quite often on the Cow so its actually the first question answered on the Final Cut Pro FAQ list.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Sebastian Swallow
    March 10, 2009 at 9:12 am
    Thanks Zane,
    I checked it out and it said Handbrake was OK but I guess not.
