Activity Forums Adobe After Effects Unknown Exception…. unexpected failure during Application Startup?
  • Unknown Exception…. unexpected failure during Application Startup?
    Posted by Randy Burleson on October 27, 2009 at 5:18 pm
    After Effects won’t open today for some reason…
    I get this error…
    I tried trashing prefs, restarting, Zapping the PRAM etc…
    CS4 on MacPro OSX 10.5.8
    Any ideas? Do I need to reinstall AE?
    Kieran Hunter replied 14 years, 3 months ago 4 Members · 4 Replies
  • Kevin Camp
    October 27, 2009 at 5:31 pm
    try removing the entire folder that the prefs are contained in. it should be in users/[username]/library/preferences/adobe/after effects its the folder named for the version number, like ‘9.0’. pull the whole folder to the desktop. and restart ae.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Randy Burleson
    October 27, 2009 at 5:40 pm
    I did the OPTION + COMMAND + SHIFT on launch and that did the trick.
    Which apparently does the same thing as deleting that folder.
    Thanks so much for responding!
  • Bethan Fairbairn
    December 28, 2011 at 10:52 pm
    I have this exact same problem but i dnt have or i cant understand where this folder is that i need to delete is, is it in the program files/adobe/support files/adobe after effects cs5 when i click computer??
  • Kieran Hunter
    May 28, 2012 at 7:15 pm
    Signed up here as I found i always end up here after I Google a problem.
    Found a fix tho, restore your fonts in ‘font book’ applications to the original ones and it loads up no problem.
