Activity Forums Adobe After Effects Unknown Exception AE CS5.5
  • Unknown Exception AE CS5.5
    Posted by Jan Van den bossche on March 6, 2012 at 9:09 pm
    I run CS5.5 on a iMac OS10.7.3 3,4GHz i7 16GB Ram.
    When I start CS5.5 I get the AE Warning: “Unknown Exception”, when I click “OK” AE starts up and works fine but it’s not really handy. I checked the forum and tried out everything…
    The warning appears when the startup session is checking : “scanning folder: file formats – camera raw”.
    I also have AECS4 installed an PSCS4.
    thanks,
    Jan
    Jan Van den Bossche
    Jan Van den bossche replied 14 years, 1 month ago 2 Members · 2 Replies
  • Aaron Spears
    August 2, 2012 at 7:49 pm
    I’m having the same problem…did you ever resolve the issue??
  • Jan Van den bossche
    August 3, 2012 at 7:23 am
    Hi Aaron,
    no solution…
    I’m just rendering without audio and then I put the audio file under the video in FCP and export again, double work and double files but the only solution…
    Jan
    Jan Van den Bossche
