Activity Forums Adobe Premiere Pro Unknown Error During Rendering Clip(s) GlitchyDropped Frames problem…
  • Unknown Error During Rendering Clip(s) GlitchyDropped Frames problem…
    Posted by Rich Tamayo on May 28, 2014 at 2:24 am
    Although I know why this happens and also know the work-around-fix, it’s really annoying and wonder if there’s a fix?
    This happens when there are any flaky frames (ie: glitchy frame or several in a row).
    The problem is that I often have a few glitchy frames here and there and it’s a real hassle to have to baby-sit the computer rendering a few minute at a time to find and delete those frames throughout a long project.
    Question: Is there a way to set in preferences, so that premiere would ignore glitchy or dropped frames, thus leaving them as-is and let the computer render the whole 4 hour program without having it stop frequently because of “UNKNOWN ERROR”?
    Daniele De piccoli replied 11 years, 10 months ago 3 Members · 4 Replies
  • Walter Soyka
    May 28, 2014 at 1:05 pm
    Are you saying your media is corrupt, and Pr is failing on the corrupt frames?
    Can you transcode your media to another format?
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Rich Tamayo
    May 28, 2014 at 4:10 pm
    Hi. thanks for your reply. Infact if the media is corrupt, from my experience, trying to “transcode” often causes another ERROR when transcoder reaches that same point(s). This has been a known issue.
  • Walter Soyka
    May 28, 2014 at 4:50 pm
    [Rich Tamayo] “Hi. thanks for your reply. Infact if the media is corrupt, from my experience, trying to “transcode” often causes another ERROR when transcoder reaches that same point(s). This has been a known issue.”
    I’m still trying to understand your problem. Do you know if it is bad source footage?
    If you cannot transcode it with Adobe Media Encoder, you may try a different compression application.
    Walter Soyka
  • Daniele De piccoli
    October 28, 2014 at 7:54 am
    I have exactly the same problem. I know the footage is corrupted, but I need it to be exported, even with the bad frames. But they occur every 2-5 seconds. I need Premiere to keep exporting. Transcoding the footage is useless, as Encoder stops at the same point.
    PLEASE HELP ME!
    Daniele.
