Activity › Forums › Adobe Premiere Pro › Unknown Error
  • Unknown Error
    Posted by Larry Gomez on April 4, 2008 at 9:49 pm
    Hi:
    I’ve just downloaded an older version of QT and I still get the unknown error message on the last frame of an uncompressed million + color movie. Does anyone know what gives? I did have the latest version of QT Pro and I got the same issue. If I use a compressor like Cinepak it will render but the quality is not up to snuff for a movie which is what I am trying to do. PLEASE HELP!
    Larry Gomez
    lgomez222@verizon.net
    Jon Barrie replied 18 years, 5 months ago 2 Members · 1 Reply
  • Jon Barrie
    April 5, 2008 at 5:03 am
    Are you sure the Newest QT version was uninstalled properly? You should probably reboot the computer after it’s been uninstalled and then reboot again once you install the 7.3.1 version.
    I’d like to know why you want to render the alpha channel (millions+) the (+) is the alpha channel you won’t get a better quality than millions, just the see through parts will come through = a bigger file size.
    Export some shorter tests, by setting the work area to a short length and make sure you set the render to work area not entire timeline. Test the millions only (the millions+ should be working though as I’ve used it plenty with the rollback without errors).
    If that’s causing prob’s do an Microsoft AVI with none compressor.
    – Jon 🙂
    How many editors does it take to change a light bulb?
    http://www.jonbarrie.net
