Activity Forums Avid Media Composer Unknown Dongles
  • Unknown Dongles
    Posted by Max Turri on August 12, 2009 at 6:33 pm
    hi , recently bought from ebay 9600/350 with avbv and janus with
    2 dongles but cant find out what software i need to make it working.
    if someone can help me to clear about this jurassic HW. the dumps..
    Dump for key #dongle1
    Avid System ID: *****
    Product: Media Composer
    Model: Avid Xpress
    Version: 0.0.x (0)
    Extra Options:
    AVR 3s
    4 Video Tracks
    AVR 75
    Xpress Pro Effects
    Xpress Fast Render Effects
    Xpress RealTime Play Effects
    AVR 77
    Complete List:
    Timeline/pict
    bins/etc
    + AVR 3s
    Digitize Window
    Edit Window
    Deck control
    AVR 12 *
    Full Rate Only
    Pre-Vis-1 Title Tool
    + 4 Video Tracks
    Picture-In-Picture Effect *
    opt_PreVis_BC2
    No AutoSync
    TC Base
    8 Audio Tracks
    + AVR 75
    + Xpress Pro Effects
    MCX UI
    AVR 71
    MCX base effects
    + Xpress Fast Render Effects
    + Xpress RealTime Play Effects
    + AVR 77
    Items marked with “+” are extra options. All others are standard to the model.
    Dump for key #dongle2
    Model: Model 1000
    Version: 0.0.x (0)
    Extra Options:
    No AutoSync
    Complete List:
    Enhanced Audio (2n2/CD)
    Timeline/pict bins/etc
    AVR 3s
    Digitize Window
    Edit Window
    Deck control
    Dissolves only
    AVR 70
    AVR 26
    Full Rate Only
    Pre-Vis-1
    Visual Effects
    Transitional Vis Effects
    Programmable Vis Effects
    Title Tool
    8 Video Tracks
    AVR 25
    + No AutoSync
    TC Base Real
    Time Color Correction
    Real Time Dissolves/Wipes
    Real Time 2D
    DVE Real Time Titles
    AVR 75
    Brian Cutts replied 17 years ago 2 Members · 1 Reply
  • Brian Cutts
    August 20, 2009 at 10:13 pm
    You’ll probably find that Media Composer 7.2 software will install and run under those dongles. If you use the MC1000 dongle it will be a Media Composer. If you use the Xpress dongle it will run (using the same installed software) as an Xpress system which is a cut down Media Composer.
