Activity Forums Avid Media Composer Unknown Compression Type error
  • Unknown Compression Type error
    Posted by Mark Norgate on November 9, 2012 at 8:40 am
    I’m trying to conform a sequence and all has worked fine except this little run of clips that displays the error ‘you cannot import this type of clip into a bin’ then I get an UNKNOWN_COMPRESSION_TYPE error. In the bin where I import the AMA clips to, under video it displays Unsupported (HD1080i). This is a HD1080i project and all the other footage is perfectly happy.
    Help?!
    Mark Norgate replied 13 years, 9 months ago 1 Member · 1 Reply
  • Mark Norgate
    November 9, 2012 at 8:42 am
    I’m running a PC with Avid 5.0.3 if that helps.
