Activity › Forums › Maxon Cinema 4D › unintentional overshoot
  • unintentional overshoot
    Posted by Jonas Espinoza on January 16, 2007 at 9:03 pm
    am offsetting start and end in “adjustment” but am having an overshoot like effect where my outline isnt continuous, its multiple strokes instead of one clean outline.
    i have all my geometry now as one object and outline culling. corners are still not joining. am i missing something to make a clean continuous outline/line
    Mylenium replied 19 years, 8 months ago 3 Members · 2 Replies
  • Adam Trachtenberg
    January 16, 2007 at 11:24 pm
    Sounds like you’re talking about Sketch and Toon? Did you enable the Strokes option? If so then you need to play with some of the options in the strokes tab.
  • Mylenium
    January 17, 2007 at 6:23 am
    Modify your stroke based on screen angle or the facing angles in your objects. This does not completely eliminate the overshoot, though. also check your model. Sounds to me like you are also using very fine details in some areas which cause multiple strokes to appear in the same place (each edge gets a stroke, but the edges are smaller than the strokes themselves, so they overlap).
    Mylenium
    [Pour Myl
