Activity › Forums › Apple Final Cut Pro Legacy › Uninstall Matrox MXO
  • Uninstall Matrox MXO
    Posted by Tom Wolsky on June 6, 2007 at 10:54 pm
    Does anybody know how to get rid of the Matrox MXO presets? The uninstaller does not remove them, and they are not in /Library/Application Support/Final Cut Pro System Support/Custom Settings.
    Thanks very much.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
    Tom Wolsky replied 19 years, 3 months ago 3 Members · 4 Replies
  • James Reid
    June 6, 2007 at 11:20 pm
    [Tom Wolsky] “they are not in /Library/Application Support/Final Cut Pro System Support/Custom Settings.”
    Are you sure?
    I have folder in there with 49 presets.
  • James Reid
    June 6, 2007 at 11:30 pm
    Addendum:
    If you are using FCP Attic or FCP Rescue and have backed up while
    MXO was installed, then you refresh your FCP prefs after you uninstall
    MXO, they will all come back.
    (I had this problem with old Decklink setups after I installed my Kona LH)
  • Shane Ross
    June 7, 2007 at 1:10 am
    Go into the A/V settings, Sequence presets tab and highlight and delete the ones you don’t want.
    Took me a while to find those, as I had Decklink ones to delete.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Tom Wolsky
    June 7, 2007 at 4:50 am
    Thanks Shane. I forgot they get embedded in preferences.
    All the best,
    Tom
