Activity › Forums › Avid Media Composer › Uninstall Avid Application Manager
  • Uninstall Avid Application Manager
    Posted by Jason Brewer on November 8, 2015 at 7:43 pm
    I’m trying to wipe clean my Avid.
    I’ve followed all the Manual Uninstall from the Avid website. Which looks like this:
    1) Apps > Avide editing program >Delete
    2) HD – Library > application support > Avid > Delete
    3) Applications > utilities > avid Utilities > delete
    I’ve run the Uninstaller.
    But when I go to reinstall – I keep seeing Application Manager as an Upgrade (see image)
    It even says this : “Application Manager will not be uninstalled when Editor is uninstalled.”
    So my Question is – How do I uninstall the Application Manager on OS X Yosemite.
    Thanks in Advance.
    Jason Brewer replied 10 years, 10 months ago 2 Members · 2 Replies
  • Shane Ross
    November 9, 2015 at 2:28 am
    You don’t just DELETE the Avid software…you need to UNINSTALL it. There’s an uninstaller in the Applications folder…called AVID UNINSTALLERS. In there is also the Application Manager uninstaller. You shouldn’t delete anything manually, until after you ran the uninstaller.
    Shane
    Little Frog Post
  • Jason Brewer
    November 9, 2015 at 3:40 am
    Yes, I now see the Applications Manager Uninstaller in the Uninstaller folder
    I was following this tutorial FROM AVID.
    https://avid.force.com/pkb/articles/en_US/How_To/How-to-Manual-Uninstall-Avid-Editor-Applications-MAC
    This tutorial uses an older version of Avid where Applications Manager Uninstaller was not contained in the Uninstaller folder
    [Shane Ross] “You don’t just DELETE the Avid software…you need to UNINSTALL it.
    – I agree but the folks at Avid who posted the link above seem to think otherwise.
    [Shane Ross]There’s an uninstaller in the Applications folder…called AVID UNINSTALLERS. In there is also the Application Manager uninstaller. You shouldn’t delete anything manually, until after you ran the uninstaller.”
    – On reinstall I found this folder. Which I will run next time.
    Thanks.
