Activity Forums Avid Media Composer Uninstall and re-install Media Composer on a Mac
  • Uninstall and re-install Media Composer on a Mac
    Posted by Jack Entonces on August 9, 2008 at 8:13 pm
    i want to uninstall and re-install my Avid Media Composer v.3.
    Is there a correct way to do this on a mac?
    I’ve searched on the Avid site and can’t find anything on how to do this.
    can someone please tell me, or kindly direct me to a link that
    gives directions to uninstall and re-install AMC v3 from a Mac …
    I will be very grateful.
    thank you
    Daniel Low replied 17 years, 11 months ago 4 Members · 3 Replies
  • Joe Womble
    August 9, 2008 at 10:13 pm
    Jack,
    When uninstalling and re-installing the software, there may be some folders that you will have to clean up before the re-install (or before installing newer builds). To clean up folders:
    1. Uninstall your existing Avid editing applications. This includes any helper applications such as FilmScribe™ or EDL Manager.
    2. Remove the following Registry keys on your system if they still exist after the uninstallation process.
    HKLM/Software/Avid Technology/productname
    HKLM/Software/Avid Technology/AVX Plug-ins
    3. From the following folders, remove any folders that do not have custom data in them that you want to keep. If you do have custom data, copy the data to the new locations after step 4.
    C:/Documents and Settings/AllUsers/ApplicationData/Avid/productname
    C:/Program Files/Avid/Productname
    (Vista) C:/ProgramData/Avid/Productname
    4. Install the new Avid editing application.
    MAC Uninstall Issue:
    There might be an issue with the way the Avid Uninstaller application runs. This bug is where the Uninstaller file may accidentally delete your icons from the Dock. This would only happen if you are Uninstalling software to move up to a new Build, or Uninstalling the software for troubleshooting reasons. Avid is aware of this bug and is addressing it.
    Regards,
    Joe Womble
  • Job Ter burg
    August 10, 2008 at 6:07 am
    Where on a Mac is the Registry located?
  • Daniel Low
    September 19, 2008 at 11:11 am
    LMAO
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
