Activity › Forums › Adobe After Effects › Uniform speed between two paths
  • Uniform speed between two paths
    Posted by Themystical on March 16, 2007 at 1:07 am
    Hi to everyone, first time first here.
    I just started using AE7 and after whatching every tutorial on the creativecow website I got a pretty good hand at it, however I’m having a tiny (probably common) problem matching the timing of two or more objects moving on different paths.
    Here’s a simple gif to show you the problem.
    https://img407.imageshack.us/img407/4172/timingzo4.gif
    See? the left dot is moving on a straight path and an horizontal line moves with it, the right dot wont match the other’s speed ending up missing the horizontal line intersection.
    Basically the path on the left has been copied on the right and with the bezier point in the middle streched a bit to form a S shape.
    The 2 black dots start at the same time and end at the same time but in between…how do I make both dots to travel at the same speed?
    I’ve been searching the forums for an asnwer in old posts but I fail, any help greatly appreciated.
    TheMystical
    Themystical replied 19 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
