Activity Forums Maxon Cinema 4D Unicycle suspension
  • Unicycle suspension
    Posted by Seth Olson on April 25, 2016 at 10:44 pm
    im trying to get a unicycle suspension working, but i want the rig to only bounce on the Y, and not have a shift on the X and Z. It currently wants to fall over after landing. Im using spring dynamics, but open to other suggestions.
    Brian Jones replied 10 years, 4 months ago 2 Members · 2 Replies
  • Seth Olson
    April 26, 2016 at 3:41 am
    Here is a test file. You can see the top object falls over after the spring has settled. I want to keep that upright.
    10017_springtest.c4d.zip
  • Brian Jones
    April 26, 2016 at 2:42 pm
    the spring is a dynamic object with free rotating ends it can’t be stopped unless you limit things. A Slider connector is probably the easiest
    10020_springtest3.c4d.zip
