Activity › Forums › Adobe Premiere Pro › Ungluing the palettes
Posted by Darren Edwards on December 19, 2007 at 2:40 pmOn XP machines, is it true that you can’t unglue CS2’s palettes but you can in CS3?
Darren.
x-gf.com
Vince Becquiot replied 18 years, 9 months ago 4 Members · 6 Replies -
Jon Barrie
December 20, 2007 at 1:15 amUnglue… not exactly sure what you mean. But you can rearrange the workspace exactly the same way as CS3.
– Jon 🙂 -
Richard Baim
December 20, 2007 at 2:05 amYou can create a floating panel in either Pro 2 or CS3 by holding down the Contol key and clicking on the series of dots in the upper left corner of any panel. Move the panel where you want it and then release.
Rich Baim
Darren Edwards
December 20, 2007 at 2:18 pmI see. Strange way to do things. I presumed it would be
as simple as right-clicking the palette’s top-right-hand-
corner arrow as in AE7. Then again, it seems that unless
one’s using an Matrox accelerated machine, it’s tough
going with the ol’CS range of PPro?Darren.
x-gf.com
Vince Becquiot
December 20, 2007 at 4:06 pmYou should be able to simply right click on either top corner of the panel and select undock ?
Vince
Darren Edwards
December 21, 2007 at 1:54 pmThere is no ‘undock’ option in PPro2, unless I’m
missing an update or something. The CTRL-dots things
worked fine, though, so I got there eventually. 🙂D.
x-gf.com
Vince Becquiot
December 21, 2007 at 4:47 pmYou are correct. It just seems so obvious, I wonder why they didn’t start with that.
Vince
