Activity Forums Adobe After Effects Unfurling spiral
  • Unfurling spiral
    Posted by Ed Stables on April 1, 2016 at 8:23 pm
    Hi
    I’m trying to generate a naturally unfurling spiral path, like the motion of unfurling a carpet. It need only be 2D. I know this kind of effect is actually pretty do-able in C4D, but it would be incredibly useful to have an unfurling motion path in AE, which could then be used in conjunction with Trapcode plugins, etc.
    I have seen some things done with repeaters but they don’t give me the animated path I need. In fact the longer I spend thinking about the problem, the more complicated it seems to be.
    I have been using illustrator to measure the distance of each segment of my spiral. Then I’ve laid out all the lengths end to end in AE: the intersections between each are where my vertices need to end up. I’ve then taken my spiral path and used a ‘Wheel’ expression to set it rolling along the ground.
    The first problem to address is that a spiral loses diameter as it unravels, affecting its rate of rotation.
    The second big problem is that I need a way to keep vertices which are no longer rotating stationary, whilst continuing to revolve the rest of the spiral.
    I would be amazed and very grateful if anyone had a solution.
    Thank you
    Ed
    Ed Stables replied 10 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
