Activity Forums Apple Final Cut Pro Legacy Unexplicable quit with FCP5 on G4DP
  • Unexplicable quit with FCP5 on G4DP
    Posted by Amund Lie on December 31, 2005 at 4:30 pm
    Hello,
    I have a (to me) novel problem, which is FCP5 quitting right after startup as soon as all the windows have appeared on the screen.
    I have installed FCP5 on my old G4 dual 1,4ghz with 1Gig RAM. This machine previously worked fine with FCP 4.5 with OS 10.3.8, except I haven’t used it for a while and not with 10.4.x
    I have tried clean-install, then removing plugins and now completely erasing the internal drive with new installation of everything from OSX10.4 and FCP Studio disks, but the problem persists. Also tried removing each memory module in turn, still no change. Other FCP Studio applications work normally, also other memory-intensive programs work fine. Variations of upgrades makes no difference, the quitting happens in the exact same way every time.
    Could it be as simple as not enough RAM? (The system still meets the minimum requirements though)
    Below is the whole crash-report if anyone is interested.
    regards,
    Amund
    Date/Time: 2005-12-31 17:23:54.377 +0100
    OS Version: 10.4.3 (Build 8F46)
    Report Version: 3
    Command: Final Cut Pro
    Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    Parent: WindowServer [60]
    Version: 5.0.4 (5.0.4)
    Build Version: 2
    Project Name: FCPApp
    Source Version: 512141418
    PID: 204
    Thread: 0
    Exception: EXC_BAD_ACCESS (0x0001)
    Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x000000fc
    Thread 0 Crashed:
    0 com.apple.FinalCutPro 0x00433dec SetupSrcCanvasN(XXGlobals*, EffectTree*, long, long, Output*, bool*) + 740
    1 com.apple.FinalCutPro 0x00432f28 DecodeEffectFrameN(XXGlobals*, EffectTree*, long, unsigned char, Output*, bool*) + 268
    2 com.apple.FinalCutPro 0x0043626c DecodePipeTree(XXGlobals*, VideoPipe*, Output*) + 836
    3 com.apple.FinalCutPro 0x00405eb4 FCPMediaHandler::RenderFrames(long long, bool) + 3552
    4 com.apple.FinalCutPro 0x004043f0 FCPMediaHandler::Idle(long, long, long*, TimeRecord*) + 452
    5 com.apple.FinalCutPro 0x0040a458 FCPMHIdle(FCPMediaHandler*, long, long, long*, TimeRecord*) + 16
    6 …ple.CoreServices.CarbonCore 0x90b5a34c CallComponentFunctionCommon + 1152
    7 com.apple.FinalCutPro 0x0040a77c FCPMHDispatch(ComponentParameters*, char**) + 60
    8 …ple.CoreServices.CarbonCore 0x90b59e68 CallComponent + 260
    9 …ickTimeComponents.component 0x9903e244 MediaIdle + 52
    10 …ickTimeComponents.component 0x9897d66c doGenericIdle + 2180
    11 …ickTimeComponents.component 0x989797c8 GenericMoviesTask + 604
    12 …ple.CoreServices.CarbonCore 0x90b5a34c CallComponentFunctionCommon + 1152
    13 …ickTimeComponents.component 0x9897b50c GenericComponentDispatch + 88
    14 …ple.CoreServices.CarbonCore 0x90b59e68 CallComponent + 260
    15 com.apple.FinalCutPro 0x0040a79c FCPMHDispatch(ComponentParameters*, char**) + 92
    16 …ple.CoreServices.CarbonCore 0x90b59e68 CallComponent + 260
    17 com.apple.QuickTime 0x9467cd8c MediaMoviesTask + 52
    18 com.apple.QuickTime 0x9466bcac TaskMovie_priv + 3136
    19 com.apple.QuickTime 0x946c9cd8 MoviesTask_priv + 108
    20 com.apple.FinalCutPro 0x001d0910 DoMoviesTask(KGPlayerRec*) + 2664
    21 com.apple.FinalCutPro 0x001d10a8 RTDrawFrame(KGPlayerRec*, double, double, unsigned char) + 76
    22 com.apple.FinalCutPro 0x001d1bc4 DisplayMovie(KGPlayerRec*) + 624
    23 com.apple.FinalCutPro 0x001dc894 pKGPlayerUpdate(KGPlayerRec*) + 224
    24 com.apple.FinalCutPro 0x001d210c DelayTimer(long, long, KGDictInt*, void*) + 128
    25 com.apple.FinalCutPro 0x0015ea4c KGTimerInvoke(__EventLoopTimer*, void*) + 236
    26 com.apple.CoreFoundation 0x90770aec __CFRunLoopDoTimer + 184
    27 com.apple.CoreFoundation 0x9075d464 __CFRunLoopRun + 1680
    28 com.apple.CoreFoundation 0x9075ca18 CFRunLoopRunSpecific + 268
    29 com.apple.HIToolbox 0x931861e0 RunCurrentEventLoopInMode + 264
    30 com.apple.HIToolbox 0x93185874 ReceiveNextEventCommon + 380
    31 com.apple.HIToolbox 0x931caca4 AcquireNextEventInMode + 72
    32 com.apple.HIToolbox 0x931caa94 RunApplicationEventLoop + 132
    33 com.apple.FinalCutPro 0x00167598 KGMainEvent(void*) + 64
    34 com.apple.FinalCutPro 0x002dde40 main + 100
    35 com.apple.FinalCutPro 0x0000d83c _start + 392
    36 dyld 0x8fe01048 _dyld_start + 60
    Thread 1:
    0 libSystem.B.dylib 0x9002b8a8 semaphore_wait_signal_trap + 8
    1 libSystem.B.dylib 0x9003001c pthread_cond_wait + 488
    2 com.apple.FinalCutPro 0x0041626c Synchronizable::Wait() + 60
    3 com.apple.FinalCutPro 0x00406fe0 DisplayQueue::Run() + 744
    4 com.apple.FinalCutPro 0x0043e460 Thread::RunHelper(void*) + 32
    5 libSystem.B.dylib 0x9002b200 _pthread_body + 96
    Thread 2:
    3 com.apple.FinalCutPro 0x004b75f8 WorkUnitPerformer::Run() + 84
    Thread 3:
    0 libSystem.B.dylib 0x9000b208 mach_msg_trap + 8
    1 libSystem.B.dylib 0x9000b15c mach_msg + 60
    2 com.apple.CoreFoundation 0x9075d114 __CFRunLoopRun + 832
    3 com.apple.CoreFoundation 0x9075ca18 CFRunLoopRunSpecific + 268
    4 com.apple.audio.CoreAudio 0x914001dc HALRunLoop::OwnThread(void*) + 264
    5 com.apple.audio.CoreAudio 0x913fff7c CAPThread::Entry(CAPThread*) + 96
    6 libSystem.B.dylib 0x9002b200 _pthread_body + 96
    Thread 4:
    4 com.apple.CoreFoundation 0x9076be78 CFRunLoopRun + 52
    5 com.apple.AVCVideoServices 0x00c6bd94 AVS::AVCVideoServicesThreadStart(AVS::AVCVideoServicesThreadParams*) + 168
    Thread 5:
    0 libSystem.B.dylib 0x90053f68 semaphore_timedwait_signal_trap + 8
    1 libSystem.B.dylib 0x900702c8 pthread_cond_timedwait_relative_np + 556
    2 …ple.CoreServices.CarbonCore 0x90b745e4 TSWaitOnSemaphoreCommon + 176
    3 …ickTimeComponents.component 0x98928460 ReadSchedulerThreadEntryPoint + 436
    4 libSystem.B.dylib 0x9002b200 _pthread_body + 96
    Thread 6:
    3 …ple.CoreServices.CarbonCore 0x90b7f08c AIOFileThread(void*) + 520
    Thread 0 crashed with PPC Thread State 64:
    srr0: 0x0000000000433dec srr1: 0x000000000200f030 vrsave: 0x0000000000000000
    cr: 0x28242224 xer: 0x0000000000000004 lr: 0x0000000000433d9c ctr: 0x0000000090001350
    r0: 0x000000000fe669e0 r1: 0x00000000bfffdcd0 r2: 0x0000000000000000 r3: 0x00000000025fba4c
    r4: 0x0000000000000000 r5: 0x00000000000003e8 r6: 0x00000000ffffffff r7: 0x0000000000000001
    r8: 0x0000000000000000 r9: 0x0000000000000000 r10: 0x000000000000008d r11: 0x00000000009083d0
    r12: 0x0000000090001350 r13: 0x0000000000000000 r14: 0x0000000000000000 r15: 0x0000000000000000
    r16: 0x00000000bfffe2a0 r17: 0x0000000000000000 r18: 0x0000000000000001 r19: 0x0000000000000000
    r20: 0x0000000000000000 r21: 0x000000000270da20 r22: 0x000000000fe65cf0 r23: 0x000000000aad7090
    r24: 0x000000000aaeb510 r25: 0x0000000000000000 r26: 0x00000000025fb810 r27: 0x0000000000000000
    r28: 0x0000000000000000 r29: 0x000000000fe669e0 r30: 0x00000000025fba4c r31: 0x0000000000433b1c
    Binary Images Description:
    0x1000 – 0x706fff com.apple.FinalCutPro 5.0.4 /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    0xc05000 – 0xc39fff com.apple.proapps.MIO 1.0 /Applications/Final Cut Pro.app/Contents/Frameworks/MIO.framework/Versions/A/MIO
    0xc5e000 – 0xc88fff com.apple.AVCVideoServices 17.0.0 (17) /Applications/Final Cut Pro.app/Contents/Frameworks/AVCVideoServices.framework/Versions/A/AVCVideoServices
    0xca8000 – 0xd68fff ProMediaIOClasses /Applications/Final Cut Pro.app/Contents/Frameworks/ProMediaIOClasses.framework/Versions/A/ProMediaIOClasses
    0xde8000 – 0xe39fff ProMediaIO /Applications/Final Cut Pro.app/Contents/Frameworks/ProMediaIO.framework/Versions/A/ProMediaIO
    0x1ab5000 – 0x1ae5fff com.apple.FinalCutPro.Plugins.AfterEffects 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AfterEffects.bundle/Contents/MacOS/AfterEffects
    0x1d05000 – 0x1d0ffff com.apple.FinalCutPro.Plugins.AudioGroupsExport 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AudioGroupsExport.bundle/Contents/MacOS/AudioGroupsExport
    0x1d16000 – 0x1d35fff com.apple.FinalCutPro.Plugins.AudioMixer 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AudioMixer.bundle/Contents/MacOS/AudioMixer
    0x1d46000 – 0x1d52fff com.apple.FinalCutPro.Plugins.Cache Manager 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Cache Manager.bundle/Contents/MacOS/Cache Manager
    0x1d58000 – 0x1d72fff com.apple.FinalCutPro.CinemaTools 3.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Cinema Tools.bundle/Contents/MacOS/Cinema Tools
    0x1e0b000 – 0x1eb7fff com.apple.FinalCutPro.Plugins.Browser 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Browser.bundle/Contents/MacOS/Browser
    0x1eda000 – 0x1eecfff com.apple.FinalCutPro.Plugins.CTHelper 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/CTHelper.bundle/Contents/MacOS/CTHelper
    0x1ef8000 – 0x1f23fff com.apple.FinalCutPro.Plugins.EditTape 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/EditTape.bundle/Contents/MacOS/EditTape
    0x1f36000 – 0x1f86fff com.apple.FinalCutPro.Plugins.EDL Export 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/EDL Export.bundle/Contents/MacOS/EDL Export
    0x1f9f000 – 0x1fadfff com.apple.FinalCutPro.Plugins.Effect Builder 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Effect Builder.bundle/Contents/MacOS/Effect Builder
    0x1fb4000 – 0x1fc6fff com.apple.FinalCutPro.Plugins.FCPExtPluginSupport 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FCPExtPluginSupport.bundle/Contents/MacOS/FCPExtPluginSupport
    0x1fd1000 – 0x1fe8fff com.apple.FinalCutPro.Plugins.FilterCustomEd 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FilterCustomEd.bundle/Contents/MacOS/FilterCustomEd
    0x1ff0000 – 0x1ffafff com.apple.FinalCutPro.Plugins.NuggetExport 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/NuggetExport.bundle/Contents/MacOS/NuggetExport
    0x51e3000 – 0x51f5fff com.apple.FinalCutPro.Plugins.GenViewer 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/GenViewer.bundle/Contents/MacOS/GenViewer
    0x5832000 – 0x5868fff com.apple.FinalCutPro.Plugins.FCS Engine 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FCS Engine.bundle/Contents/MacOS/FCS Engine
    0x5878000 – 0x5892fff com.apple.FinalCutPro.Plugins.FilterViewer 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FilterViewer.bundle/Contents/MacOS/FilterViewer
    0x5899000 – 0x58bffff com.apple.FinalCutPro.Plugins.Flash 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Flash.bundle/Contents/MacOS/Flash
    0x58d2000 – 0x590efff com.apple.FinalCutPro.Plugins.G4 Accelerator 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/G4 Accelerator.bundle/Contents/MacOS/G4 Accelerator
    0x5919000 – 0x5924fff com.apple.FinalCutPro.Plugins.LayerFileReader 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/LayerFileReader.bundle/Contents/MacOS/LayerFileReader
    0x592b000 – 0x597ffff com.apple.FinalCutPro.Plugins.Media Manager 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Media Manager.bundle/Contents/MacOS/Media Manager
    0x5990000 – 0x599afff com.apple.FinalCutPro.Plugins.MolokiniSupport 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/MolokiniSupport.bundle/Contents/MacOS/MolokiniSupport
    0x59a2000 – 0x59bafff com.apple.FinalCutPro.Frameworks.MolokiniTranslation 1.0 /Applications/Final Cut Pro.app/Contents/Frameworks/MolokiniTranslation.framework/Versions/A/MolokiniTranslation
    0x59c9000 – 0x59e3fff com.apple.FinalCutPro.Plugins.Motion Viewer 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Motion Viewer.bundle/Contents/MacOS/Motion Viewer
    0x59eb000 – 0x5a0efff com.apple.FinalCutPro.Plugins.Movie Analyzer 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Movie Analyzer.bundle/Contents/MacOS/Movie Analyzer
    0x5a1e000 – 0x5a33fff com.apple.FinalCutPro.Plugins.Movie Viewer 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Movie Viewer.bundle/Contents/MacOS/Movie Viewer
    0x5a3a000 – 0x5aebfff com.apple.FinalCutPro.Plugins.OMF Audio Export 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/OMF Audio Export.bundle/Contents/MacOS/OMF Audio Export
    0x5b10000 – 0x5b25fff com.apple.FinalCutPro.Plugins.P2Support 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/P2Support.bundle/Contents/MacOS/P2Support
    0x5b32000 – 0x5b41fff com.apple.FinalCutPro.Plugins.Perf Analyzer 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Perf Analyzer.bundle/Contents/MacOS/Perf Analyzer
    0x5b49000 – 0x5b61fff com.apple.FinalCutPro.Plugins.ProAppsIntegration 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/ProAppsIntegration.bundle/Contents/MacOS/ProAppsIntegration
    0x5b71000 – 0x5b84fff com.apple.FinalCutPro.Plugins.Pulldown Support 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Pulldown Support.bundle/Contents/MacOS/Pulldown Support
    0x5b8d000 – 0x5bcafff com.apple.FinalCutPro.Plugins.QTM Reader 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/QTM Reader.bundle/Contents/MacOS/QTM Reader
    0x5bde000 – 0x5bedfff com.apple.FinalCutPro.Plugins.QuickView 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/QuickView.bundle/Contents/MacOS/QuickView
    0x5bf4000 – 0x5c08fff com.apple.FinalCutPro.Plugins.Relink Media 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Relink Media.bundle/Contents/MacOS/Relink Media
    0x5c11000 – 0x5c19fff com.apple.FinalCutPro.Plugins.Text Window 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Text Window.bundle/Contents/MacOS/Text Window
    0x5c1f000 – 0x5ca4fff com.apple.FinalCutPro.Plugins.Timeline Editor 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Timeline Editor.bundle/Contents/MacOS/Timeline Editor
    0x5cbe000 – 0x5cccfff com.apple.FinalCutPro.Plugins.Transcoder 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Transcoder.bundle/Contents/MacOS/Transcoder
    0x5cd4000 – 0x5cecfff com.apple.FinalCutPro.Plugins.Transition Viewer 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Transition Viewer.bundle/Contents/MacOS/Transition Viewer
    0x5cf4000 – 0x5d10fff com.apple.FinalCutPro.Plugins.Trimming 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Trimming.bundle/Contents/MacOS/Trimming
    0x5d18000 – 0x5d26fff com.apple.FinalCutPro.Plugins.VDUSupport 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VDUSupport.bundle/Contents/MacOS/VDUSupport
    0x5d2e000 – 0x5d47fff com.apple.FinalCutPro.Plugins.VideoLog 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VideoLog.bundle/Contents/MacOS/VideoLog
    0x5d50000 – 0x5d70fff com.apple.FinalCutPro.Plugins.VoiceOver 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VoiceOver.bundle/Contents/MacOS/VoiceOver
    0x5d7b000 – 0x5d91fff com.apple.FinalCutPro.Plugins.Waveform Monitor 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Waveform Monitor.bundle/Contents/MacOS/Waveform Monitor
    0x5d99000 – 0x5df9fff com.apple.FinalCutPro.Plugins.XML Support 5.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/XML Support.bundle/Contents/MacOS/XML Support
    0x6239000 – 0x6244fff com.apple.LiveType.component 2.0.2 /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
    0x6252000 – 0x6276fff com.apple.fcp.DVOutputUnit 1.3 /Applications/Final Cut Pro.app/Contents/Resources/DVOutputUnit.bundle/Contents/MacOS/DVOutputUnit
    0x6433000 – 0x644afff com.apple.FCP Uncompressed 422.component 1.2 /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
    0x6450000 – 0x64c9fff com.apple.DVCPROHDCodec 1.1.1 (209) /Library/QuickTime/DVCPROHDCodec.component/Contents/MacOS/DVCPROHDCodec
    0x64df000 – 0x64f5fff com.apple.IMXCodec 1.0 (114) /Library/QuickTime/IMXCodec.component/Contents/MacOS/IMXCodec
    0x654c000 – 0x65fcfff com.apple.AppleHDVCodec 1.0 (129) /Library/QuickTime/AppleHDVCodec.component/Contents/MacOS/AppleHDVCodec
    0x661a000 – 0x6683fff com.apple.AppleIntermediateCodec 1.0.1 (124) /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
    0x6698000 – 0x6711fff com.apple.applepixletvideo 1.2.5 (1.2d5) /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
    0x6aef000 – 0x6b33fff com.apple.soundtrackpro.integration 1.0 /Library/Application Support/ProApps/Bundles/Soundtrack Pro Integration.bundle/Contents/MacOS/Soundtrack Pro Integration
    0x6cfd000 – 0x6cfefff com.apple.aoa.halplugin 2.5.6 (2.5.6b5) /System/Library/Extensions/IOAudioFamily.kext/Contents/PlugIns/AOAHALPlugin.bundle/Contents/MacOS/AOAHALPlugin
    0x717d000 – 0x71cc3c7 CarbonLibpwpc PEF binary: CarbonLibpwpc
    0x71cc3d0 – 0x71e46bd Apple;Carbon;Multimedia PEF binary: Apple;Carbon;Multimedia
    0x7276fa0 – 0x7277052 CFMPriv_CoreFoundation PEF binary: CFMPriv_CoreFoundation
    0x7277240 – 0x72772f5 CFMPriv_DVComponentGlue PEF binary: CFMPriv_DVComponentGlue
    0x7277510 – 0x72775b3 CFMPriv_QuickTime PEF binary: CFMPriv_QuickTime
    0x7277620 – 0x7277697 CFMPriv_System PEF binary: CFMPriv_System
    0x7277910 – 0x72779e0 CFMPriv_CarbonSound PEF binary: CFMPriv_CarbonSound
    0x7277a50 – 0x7277b23 CFMPriv_CommonPanels PEF binary: CFMPriv_CommonPanels
    0x7277bf0 – 0x7277cab CFMPriv_Help PEF binary: CFMPriv_Help
    0x7277cb0 – 0x7277d7a CFMPriv_HIToolbox PEF binary: CFMPriv_HIToolbox
    0x7277df0 – 0x7277ec6 CFMPriv_HTMLRendering PEF binary: CFMPriv_HTMLRendering
    0x7277f30 – 0x7278003 CFMPriv_ImageCapture PEF binary: CFMPriv_ImageCapture
    0x7278080 – 0x7278165 CFMPriv_NavigationServices PEF binary: CFMPriv_NavigationServices
    0x72781d0 – 0x72782a6 CFMPriv_OpenScripting?MacBLib PEF binary: CFMPriv_OpenScripting?MacBLib
    0x7278370 – 0x727842e CFMPriv_Print PEF binary: CFMPriv_Print
    0x7278440 – 0x727850d CFMPriv_SecurityHI PEF binary: CFMPriv_SecurityHI
    0x7278580 – 0x7278662 CFMPriv_SpeechRecognition PEF binary: CFMPriv_SpeechRecognition
    0x72786d0 – 0x72787a3 CFMPriv_CarbonCore PEF binary: CFMPriv_CarbonCore
    0x7278810 – 0x72788e3 CFMPriv_OSServices PEF binary: CFMPriv_OSServices
    0x72789b0 – 0x7278a72 CFMPriv_AE PEF binary: CFMPriv_AE
    0x7278a80 – 0x7278b45 CFMPriv_ATS PEF binary: CFMPriv_ATS
    0x7278bb0 – 0x7278c87 CFMPriv_ColorSync PEF binary: CFMPriv_ColorSync
    0x7278d00 – 0x7278de3 CFMPriv_FindByContent PEF binary: CFMPriv_FindByContent
    0x7278e50 – 0x7278f2a CFMPriv_HIServices PEF binary: CFMPriv_HIServices
    0x7278f90 – 0x7279070 CFMPriv_LangAnalysis PEF binary: CFMPriv_LangAnalysis
    0x72790f0 – 0x72791d6 CFMPriv_LaunchServices PEF binary: CFMPriv_LaunchServices
    0x72792b0 – 0x7279387 CFMPriv_PrintCore PEF binary: CFMPriv_PrintCore
    0x7279390 – 0x7279452 CFMPriv_QD PEF binary: CFMPriv_QD
    0x7279550 – 0x7279639 CFMPriv_SpeechSynthesis PEF binary: CFMPriv_SpeechSynthesis
    0x7305000 – 0x7b4c30f PEF binary:
    0x80c8000 – 0x890bdbf
    x PEF binary: x
    0x8c64000 – 0x94aac47
    x PEF binary: x
    0x99bf000 – 0xa206d47
    x PEF binary: x
    0xa905000 – 0xa91ffff com.apple.fcp.TundraOutputUnit 1.3 /Applications/Final Cut Pro.app/Contents/Resources/TundraOutputUnit.bundle/Contents/MacOS/TundraOutputUnit
    0xa935000 – 0xa992fff com.apple.DVCPROHDVideoOutput 1.2 /Library/QuickTime/DVCPROHDVideoOutput.component/Contents/MacOS/DVCPROHDVideoOutput
    0xa9a5000 – 0xa9defff com.apple.audio.SoundManager.Components 3.9.1 /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
    0xa9e4000 – 0xa9ebfff com.apple.DesktopVideoOut 1.2.3 /Library/QuickTime/DesktopVideoOut.component/Contents/MacOS/DesktopVideoOut
    0xab05000 – 0xababfff com.apple.DVCPROHDMuxer 1.2 /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
    0xabd2000 – 0xac14fff com.apple.QuickTimeFireWireDV.component 7.0.3 /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
    0xac25000 – 0xac2ffff com.apple.IOFWDVComponents 1.7.5 /System/Library/Components/IOFWDVComponents.component/Contents/MacOS/IOFWDVComponents
    0xac46000 – 0xad15fff com.apple.AECore 2.0 (2.0.1) /Library/Frameworks/AECore.framework/Versions/A/AECore
    0xadce000 – 0xaeddfff GLEngine /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
    0xaf0c000 – 0xb163fff com.apple.ATIRadeon8500GLDriver 1.4.16 (4.1.6) /System/Library/Extensions/ATIRadeon8500GLDriver.bundle/Contents/MacOS/ATIRadeon8500GLDriver
    0xb16e000 – 0xb1d6fff com.apple.ATIRage128GLDriver 1.4.4 (4.0.4) /System/Library/Extensions/ATIRage128GLDriver.bundle/Contents/MacOS/ATIRage128GLDriver
    0xb1da000 – 0xb1f3fff GLDriver /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLDriver.bundle/GLDriver
    0xb1f9000 – 0xb214fff GLRendererFloat /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
    0x10000000 – 0x10057fff com.apple.proapps.AudioMixEngine 2.0 (32) /Applications/Final Cut Pro.app/Contents/Frameworks/AudioMixEngine.framework/Versions/A/AudioMixEngine
    0x11000000 – 0x11021fff com.apple.proapps.ControlSurfaceSupport 2.0 (32) /Applications/Final Cut Pro.app/Contents/Frameworks/ControlSurfaceSupport.framework/Versions/A/ControlSurfaceSupport
    0x78820000 – 0x78820fff ProMediaIOUnit /Applications/Final Cut Pro.app/Contents/Frameworks/ProMediaIOUnit.framework/Versions/A/ProMediaIOUnit
    0x7a8c0000 – 0x7a917fff com.apple.vImageForFCP 2.0 /Applications/Final Cut Pro.app/Contents/Frameworks/vImageForFCP.framework/Versions/A/vImageForFCP
    0x7a980000 – 0x7a98dfff com.apple.proapps.ProTimecode 1.0 /Applications/Final Cut Pro.app/Contents/Frameworks/ProTimecode.framework/Versions/A/ProTimecode
    0x7ae80000 – 0x7ae85fff KGCore /Applications/Final Cut Pro.app/Contents/Frameworks/KGCore.framework/Versions/A/KGCore
    0x7d6e0000 – 0x7d6f0fff com.apple.compressor.MediaServerAPI 2.0.1 /Library/Frameworks/MediaServerAPI.framework/MediaServerAPI
    0x7d720000 – 0x7d8c0fff com.apple.compressor.transcoding 2.0.1 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/Transcoding.framework/Versions/A/Transcoding
    0x7dd00000 – 0x7dd56fff com.apple.compressor.StompUtil 2.0.1 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUtil.framework/Versions/A/StompUtil
    0x7de50000 – 0x7decbfff com.apple.compressor.StompUI 2.0.1 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUI.framework/Versions/A/StompUI
    0x7e010000 – 0x7e0b6fff com.apple.compressor.StompTypes 2.0.1 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompTypes.framework/Versions/A/StompTypes
    0x7e260000 – 0x7e294fff com.apple.compressor.ImageProcessing 2.0.1 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/ImageProcessing.framework/Versions/A/ImageProcessing
    0x7e320000 – 0x7e374fff com.apple.compressor.FilterUI 2.0.1 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/FilterUI.framework/Versions/A/FilterUI
    0x7e460000 – 0x7e460fff com.apple.compressor.stomp 2.0.1 /Library/Frameworks/Compressor.framework/Compressor
    0x7e4e0000 – 0x7e4e0fff com.apple.qmaster.swamp 2.0.1 /Library/Frameworks/Qmaster.framework/Versions/A/Qmaster
    0x7e4f0000 – 0x7e548fff com.apple.qmaster.SwampUtil 2.0.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUtil.framework/Versions/A/SwampUtil
    0x7e640000 – 0x7e6a6fff com.apple.qmaster.SwampUI 2.0.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUI.framework/Versions/A/SwampUI
    0x7e7c0000 – 0x7e7f2fff com.apple.qmaster.SwampTypes 2.0.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampTypes.framework/Versions/A/SwampTypes
    0x7e890000 – 0x7e8e7fff com.apple.qmaster.SwampService 2.0.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampService.framework/Versions/A/SwampService
    0x7e9e0000 – 0x7ea38fff com.apple.qmaster.SwampExecutor 2.0.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampExecutor.framework/Versions/A/SwampExecutor
    0x7eb40000 – 0x7ebbffff com.apple.qmaster.SwampCore 2.0.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampCore.framework/Versions/A/SwampCore
    0x7ed10000 – 0x7ed6bfff com.apple.qmaster.Status 2.0.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/Status.framework/Versions/A/Status
    0x7ee80000 – 0x7eed9fff com.apple.qmaster.ServiceControl 2.0.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ServiceControl.framework/Versions/A/ServiceControl
    0x7efe0000 – 0x7f036fff com.apple.qmaster.RequestProcessing 2.0.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/RequestProcessing.framework/Versions/A/RequestProcessing
    0x7f140000 – 0x7f229fff com.apple.qmaster.JobControl 2.0.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/JobControl.framework/Versions/A/JobControl
    0x7f490000 – 0x7f524fff com.apple.qmaster.do 2.0.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/DistributedObjects.framework/Versions/A/DistributedObjects
    0x7f6c0000 – 0x7f739fff com.apple.qmaster.ContentControl 2.0.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ContentControl.framework/Versions/A/ContentControl
    0x7f890000 – 0x7f8a9fff com.apple.qmaster.ClusterManager 2.0.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ClusterManager.framework/Versions/A/ClusterManager
    0x7f950000 – 0x7f9b8fff com.apple.LiveType.framework 2.0.2 /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType
    0x7ffd0000 – 0x7ffd8fff com.apple.AEProfiling 1.2 (13) /Applications/Final Cut Pro.app/Contents/Frameworks/AEProfiling.framework/Versions/A/AEProfiling
    0x7fff0000 – 0x80004fff com.apple.AERegistration 1.2 (51) /Applications/Final Cut Pro.app/Contents/Frameworks/AERegistration.framework/Versions/A/AERegistration
    0x80040000 – 0x80048fff com.apple.Helium 2.0.2 /System/Library/PrivateFrameworks/Helium.framework/Versions/A/Helium
    0x8fe00000 – 0x8fe54fff dyld 44.2 /usr/lib/dyld
    0x90000000 – 0x901b3fff libSystem.B.dylib /usr/lib/libSystem.B.dylib
    0x9020b000 – 0x9020ffff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib
    0x90211000 – 0x90264fff com.apple.CoreText 1.0.1 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
    0x90291000 – 0x90342fff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x90371000 – 0x906aefff com.apple.CoreGraphics 1.256.27 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x9073a000 – 0x90813fff com.apple.CoreFoundation 6.4.4 (368.25) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x9085c000 – 0x9085cfff com.apple.CoreServices 10.4 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x9085e000 – 0x90960fff libicucore.A.dylib /usr/lib/libicucore.A.dylib
    0x909ba000 – 0x90a3efff libobjc.A.dylib /usr/lib/libobjc.A.dylib
    0x90a68000 – 0x90ad6fff com.apple.framework.IOKit 1.4 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x90aed000 – 0x90afffff libauto.dylib /usr/lib/libauto.dylib
    0x90b06000 – 0x90dddfff com.apple.CoreServices.CarbonCore 671.2 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x90e43000 – 0x90ec3fff com.apple.CoreServices.OSServices 4.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x90f0d000 – 0x90f4efff com.apple.CFNetwork 4.0 (129.2) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x90f63000 – 0x90f7bfff com.apple.WebServices 1.1.2 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore
    0x90f8b000 – 0x9100cfff com.apple.SearchKit 1.0.4 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x91052000 – 0x9107bfff com.apple.Metadata 10.4.3 (121.20.2) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x9108c000 – 0x9109afff libz.1.dylib /usr/lib/libz.1.dylib
    0x9109d000 – 0x9125ffff com.apple.security 4.2 (24844) /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x91362000 – 0x9136bfff com.apple.DiskArbitration 2.1 /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x91372000 – 0x91399fff com.apple.SystemConfiguration 1.8.1 /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x913ac000 – 0x913b4fff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib
    0x913b9000 – 0x913d9fff libmx.A.dylib /usr/lib/libmx.A.dylib
    0x913df000 – 0x913e7fff libbsm.dylib /usr/lib/libbsm.dylib
    0x913eb000 – 0x91469fff com.apple.audio.CoreAudio 3.0.1 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x914a7000 – 0x914a7fff com.apple.ApplicationServices 10.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x914a9000 – 0x914e1fff com.apple.AE 1.5 (297) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x914fc000 – 0x915c9fff com.apple.ColorSync 4.4.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x9161e000 – 0x916b1fff com.apple.print.framework.PrintCore 4.3 (172.3) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x916f8000 – 0x917b5fff com.apple.QD 3.8.18 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x917f3000 – 0x91851fff com.apple.HIServices 1.5.1 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x9187f000 – 0x918a3fff com.apple.LangAnalysis 1.6.1 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x918b7000 – 0x918dcfff com.apple.FindByContent 1.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent
    0x918ef000 – 0x91931fff com.apple.LaunchServices 10.4.5 (168) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x9194d000 – 0x91961fff com.apple.speech.synthesis.framework 3.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x9196f000 – 0x919a8fff com.apple.ImageIO.framework 1.4.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x919bd000 – 0x91a85fff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib
    0x91ad3000 – 0x91ae8fff libcups.2.dylib /usr/lib/libcups.2.dylib
    0x91aed000 – 0x91b09fff libJPEG.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x91b0e000 – 0x91b7dfff libJP2.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x91b94000 – 0x91b98fff libGIF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x91b9a000 – 0x91bcbfff libRaw.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib
    0x91bcf000 – 0x91c12fff libTIFF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x91c19000 – 0x91c32fff libPng.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x91c37000 – 0x91c3afff libRadiance.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x91c3c000 – 0x91c3cfff com.apple.Accelerate 1.1.1 (Accelerate 1.1.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x91c3e000 – 0x91d28fff com.apple.vImage 2.0 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x91d30000 – 0x91d4ffff com.apple.Accelerate.vecLib 3.1.1 (vecLib 3.1.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x91dbb000 – 0x91e20fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x91e2a000 – 0x91ebcfff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x91ed6000 – 0x92466fff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x924ae000 – 0x927befff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x927eb000 – 0x92877fff com.apple.DesktopServices 1.3.1 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x928b9000 – 0x92ae3fff com.apple.Foundation 6.4.2 (567.21) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x92c01000 – 0x92cdffff libxml2.2.dylib /usr/lib/libxml2.2.dylib
    0x92cff000 – 0x92dedfff libiconv.2.dylib /usr/lib/libiconv.2.dylib
    0x92dff000 – 0x92e1dfff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x92e28000 – 0x92e82fff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x92ea0000 – 0x92ea0fff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x92ea2000 – 0x92eb6fff com.apple.ImageCapture 3.0 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x92ece000 – 0x92edefff com.apple.speech.recognition.framework 3.4 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x92eea000 – 0x92efffff com.apple.securityhi 2.0 (203) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x92f11000 – 0x92f98fff com.apple.ink.framework 101.2 (69) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x92fac000 – 0x92fb7fff com.apple.help 1.0.3 (32) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x92fc1000 – 0x92feefff com.apple.openscripting 1.2.3 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x93008000 – 0x93018fff com.apple.print.framework.Print 5.0 (190.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x93024000 – 0x9308afff com.apple.htmlrendering 1.1.2 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
    0x930bb000 – 0x9310dfff com.apple.NavigationServices 3.4.2 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
    0x93139000 – 0x93156fff com.apple.audio.SoundManager 3.9 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
    0x93168000 – 0x93175fff com.apple.CommonPanels 1.2.2 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x9317e000 – 0x93490fff com.apple.HIToolbox 1.4.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x935dc000 – 0x935e8fff com.apple.opengl 1.4.6 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x935ed000 – 0x9360efff com.apple.DirectoryService.Framework 3.0 /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
    0x93659000 – 0x93659fff com.apple.Cocoa 6.4 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x9365b000 – 0x93c8efff com.apple.AppKit 6.4.3 (824.23) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x9401a000 – 0x94089fff com.apple.CoreData 50 (77) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x940c2000 – 0x9418cfff com.apple.audio.toolbox.AudioToolbox 1.4.1 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x941e0000 – 0x941e0fff com.apple.audio.units.AudioUnit 1.4 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x941e2000 – 0x9435afff com.apple.QuartzCore 1.4.3 /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x943a4000 – 0x943e1fff libsqlite3.0.dylib /usr/lib/libsqlite3.0.dylib
    0x943e9000 – 0x94439fff libGLImage.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x94479000 – 0x944bcfff com.apple.bom 8.0 (85) /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
    0x944c8000 – 0x94500fff com.apple.vmutils 4.0.0 (85) /System/Library/PrivateFrameworks/vmutils.framework/vmutils
    0x945db000 – 0x945eafff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
    0x945f2000 – 0x945fefff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
    0x94643000 – 0x9465bfff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x94662000 – 0x948ccfff com.apple.QuickTime 7.0.3 /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
    0x94aa3000 – 0x94bd1fff com.apple.AddressBook.framework 4.0.3 (483) /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
    0x94c63000 – 0x94c72fff com.apple.DSObjCWrappers.Framework 1.1 /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
    0x94c7a000 – 0x94ca7fff com.apple.LDAPFramework 1.4.1 (69.0.1) /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x94cae000 – 0x94cbefff libsasl2.2.dylib /usr/lib/libsasl2.2.dylib
    0x94cc2000 – 0x94cf1fff libssl.0.9.7.dylib /usr/lib/libssl.0.9.7.dylib
    0x94d01000 – 0x94d1efff libresolv.9.dylib /usr/lib/libresolv.9.dylib
    0x95ca0000 – 0x95cd9fff com.apple.QTKit 7.0.3 /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
    0x96098000 – 0x9616afff com.apple.prokit 3.1 (589) /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/ProKit
    0x96906000 – 0x96945fff com.apple.audio.midi.CoreMIDI 1.5 (41) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
    0x96d2d000 – 0x96d4cfff com.apple.vecLib 3.1.1 (vecLib 3.1.1) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
    0x97463000 – 0x97524fff libGLProgrammability.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x9754f000 – 0x97550fff libGLSystem.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLSystem.dylib
    0x97552000 – 0x9755ffff com.apple.agl 2.5.6 (AGL-2.5.6) /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x97660000 – 0x9767afff com.apple.AppleVAFramework 2.4.23 /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x98916000 – 0x991c9fff com.apple.QuickTimeComponents.component 7.0.3 /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
    0x9943c000 – 0x9943ffff com.apple.QuickTimeH264.component 7.0.3 /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
    0x99441000 – 0x994c4fff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib
    0x99542000 – 0x99606fff QuickTimeH264.altivec /System/Library/QuickTime/QuickTimeH264.component/Contents/Resources/QuickTimeH264.altivec
    0x9972f000 – 0x997d3fff com.apple.QuickTimeMPEG4.component 7.0.3 /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4
    0x9a1f1000 – 0x9a1f2fff com.apple.iokit.dvcomponentglue 1.7.5 /System/Library/Frameworks/DVComponentGlue.framework/Versions/A/DVComponentGlue
    0x9a1ff000 – 0x9a243fff com.apple.viceroy.codec 31.0 (31) /System/Library/Components/VCH263Codec.component/VCH263Codec
    0x9a3a1000 – 0x9a4a3fff com.apple.audio.units.Components 1.4.1 /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
    Model: PowerMac3,6, BootROM 4.6.0f1, 2 processors, PowerPC G4 (3.3), 1.42 GHz, 1 GB
    Graphics: ATI Radeon 9000 Pro, ATY,RV250, AGP, 64 MB
    Graphics: ATY,Rage128, ATY,Rage128, PCI, 32 MB
    Memory Module: DIMM0/J21, 512 MB, DDR SDRAM, PC2700U-25330
    Memory Module: DIMM1/J22, 512 MB, DDR SDRAM, PC2700U-25330
    Network Service: Built-in Ethernet, Ethernet, en0
    PCI Card: ATY,Rage128, Display, SLOT-3
    Parallel ATA Device: PIONEER DVD-RW DVR-105,
    Parallel ATA Device: ST3120024A, 111.79 GB
    Parallel ATA Device: HDT722525DLAT80, 232.89 GB
    USB Device: Hub in Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 500 mA
    USB Device: Microsoft 3-Button Mouse with IntelliEye(TM), Microsoft, Up to 1.5 Mb/sec, 100 mA
    USB Device: ET-0405-UV1.1-1, WACOM, Up to 1.5 Mb/sec, 100 mA
    USB Device: Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 250 mA
    Amund Lie replied 20 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
