Unexplained render artifacts?
Hi there. I’m attaching a relatively simple scene, as well as screen shots of the undesired render result. I have everything set up and working, even looks good in the Redshift Viewer, but as soon as I render to files, certain frames get these weird artifacts that I can’t explain — or, more importantly, get rid of! I’ve tried removing all the materials and rendering with no lights, etc., but those artifacts persist. Not sure what else to try. (I started a test scene, thinking it’s probably my unholy cascade of Booleans, but that looked fine, and also, I tested all my Boolean geom. as editable* and it didn’t fix things). *Editable except the holes being cut, which I need for the animation. Anyway, here’s the files:
Edit: Hmm. I thought you could write descriptions for images next to the images?
