Activity Forums Adobe After Effects unexplained keyframe interpolation for path
  • unexplained keyframe interpolation for path
    Posted by Mel Ruiz on September 11, 2016 at 7:12 pm
    AE 13.8.1.38
    I am having very strange movement on the path I’m animating. I set keyframes to make one corner of a rectangular path (which I converted from a rectangle into a bezier path) move. the keyframes are where i want them. 1st: shape is a rectangle; 2nd: bottom right corner is moved up so it’s a polygon. BUT in between the keyframe the rectangle just shrinks until it’s a small square and then jumps to 2nd state at 2nd keyframe. I have never encountered anything like this.
    Any ideas??
    Roei Tzoref replied 9 years, 10 months ago 2 Members · 1 Reply
  • Roei Tzoref
    October 8, 2016 at 6:49 am
    this is unfortunately how it still works when you convert to bezier path.
    from the link: https://blogs.adobe.com/creativecloud/after-effects-cc-12-2-december-2013-update/
    IMPORTANT: When you use the Convert To Bezier Path command to convert a parametric shape path to a Bezier shape path, the Bezier path that is created does not animate well (i.e., interpolation between paths behaves strangely and unpredictably). This is related to path direction and how transformations are stored. For now, you should not use these converted paths for animated paths (interpolation between paths); but, if you do want to try, you may be able to work around the issues by reversing the path before conversion.
    you need to set the first vertex after you convert to bezier path and the animation will be o.k.
    Roei Tzoref
    After Effects Artist & Instructor
    ♫ Ae Blues Tutorials
