Activity › Forums › Apple Final Cut Pro Legacy › unexpected crashes
  • unexpected crashes
    Posted by Casey Chinn on June 19, 2006 at 9:59 pm
    I just got a new Power mac quad g5 and installed FCP 5.0.4 on it, which previously had been running on my g4 laptop. Now when i open a project I’ve been working on and try and to make edits to a title crawl effect, the program crashes. This didn’t used to happen. I’ve trashed the prefs, rebuilt the permissions, tried a host of other things. One of the things I’ve noticed is that when I launch after effects it says some of my plug-ins didn’t load because the serial numbers don’t correspond with the application. Not sure how, or why that’s happened. Trying to figure a way around it, but I suspect it is a part, if not all of the problem.
    Here’s the crash log:
    Exception: EXC_BAD_ACCESS (0x0001)
    Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x00000000
    Thread 0 Crashed:
    0 <<00000000>> 0xfffeff20 objc_msgSend_rtp + 32
    1 ATS 0x902be01c ClearStyleInfo + 84
    2 ATS 0x902b11ec LLCStyleInfoCreateActiveStyleInfo + 432
    3 com.apple.QD 0x91743f4c TATSUStyle::ConstructActiveStyleInfo() + 36
    4 com.apple.QD 0x91743f04 TATSUStyle::GetStyleInfo(LLCStyleInfo const**) + 44
    5 com.apple.QD 0x917b7a74 ATSUGlyphGetQuadraticPaths + 104
    6 x 0x0c0abf18 0xbc05000 + 4878104
    7
    x 0x0c0a3820 0xbc05000 + 4843552
    8
    x 0x0bc8f290 0xbc05000 + 565904
    9
    x 0x0bc8f500 0xbc05000 + 566528
    10
    x 0x0bc88510 0xbc05000 + 537872
    11
    x 0x0bc88494 0xbc05000 + 537748
    12
    x 0x0bc88700 0xbc05000 + 538368
    13
    x 0x0bc83ac0 0xbc05000 + 518848
    14
    x 0x0bc1becc 0xbc05000 + 93900
    15
    x 0x0bc1c124 0xbc05000 + 94500
    16
    x 0x0bcae2c8 0xbc05000 + 692936
    17
    x 0x0bc1d3dc 0xbc05000 + 99292
    18
    x 0x0bcb3cfc 0xbc05000 + 716028
    19 …CutPro.Plugins.AfterEffects 0x01c14538 CALL_PLUG_IN_PROC_WITH_COLORCHECK + 232
    20 …CutPro.Plugins.AfterEffects 0x01c1e4e0 ProcessAEFXStateRequest + 912
    21 …CutPro.Plugins.AfterEffects 0x01c1baec AECustomUIMessageProc + 3300
    22 com.apple.FinalCutPro 0x000f79a0 CustomUIProc(long, long, KGDictInt*, KGViewRecord*) + 600
    23 com.apple.FinalCutPro 0x002c9578 PPassMouseEvent(KGPanelRecord*, KGDictInt*, long) + 1484
    24 com.apple.FinalCutPro 0x002c9734 pKGPanelMessage(long, long, KGDictInt*, KGViewRecord*) + 304
    25 com.apple.FinalCutPro 0x0026dce8 ServicesPanelsMessageProc(long, long, KGDictInt*, KGPanelRecord*) + 3096
    26 com.apple.FinalCutPro 0x0026e5a4 ViewerMessageProc(long, long, KGDictInt*, KGPanelRecord*) + 264
    27 com.apple.FinalCutPro 0x002c7ff4 pKGPanelWindowProc(long, long, KGDictInt*, void*) + 104
    28 com.apple.FinalCutPro 0x002d9688 pKGSendWindowMessage(KGWindowRec*, long, long, KGDictInt*) + 172
    29 com.apple.FinalCutPro 0x0016347c HandleMouseDown(OpaqueEventRef*) + 1032
    30 com.apple.FinalCutPro 0x00165fb8 DoEvent(OpaqueEventRef*, KGDictInt*) + 804
    31 com.apple.FinalCutPro 0x003f5a64 Events(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 108
    32 com.apple.HIToolbox 0x931d7794 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 692
    33 com.apple.HIToolbox 0x931d6eec SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 372
    34 com.apple.HIToolbox 0x931ddc8c SendEventToEventTarget + 40
    35 com.apple.HIToolbox 0x93269e58 HandleMouseEventForWindow(OpaqueWindowPtr*, OpaqueEventRef*, unsigned short) + 236
    36 com.apple.HIToolbox 0x933cc9c8 HandleMouseEvent(OpaqueEventRef*) + 368
    37 com.apple.HIToolbox 0x931ddff8 ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 496
    38 com.apple.HIToolbox 0x931d79e4 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1284
    39 com.apple.HIToolbox 0x931d6eec SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 372
    40 com.apple.HIToolbox 0x931ddc8c SendEventToEventTarget + 40
    41 com.apple.HIToolbox 0x9321e9a0 ToolboxEventDispatcher + 92
    42 com.apple.HIToolbox 0x9321e92c HLTBEventDispatcher + 16
    43 com.apple.HIToolbox 0x9321cee4 RunApplicationEventLoop + 148
    44 com.apple.FinalCutPro 0x00167598 KGMainEvent(void*) + 64
    45 com.apple.FinalCutPro 0x002dde40 main + 100
    46 com.apple.FinalCutPro 0x0000d83c _start + 392
    47 dyld 0x8fe01048 _dyld_start + 60
    if any of you can read this and have ideas/recommendations, I’d appreciate it.
    -Casey
    Casey Chinn replied 20 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
