Activity Forums DaVinci Resolve Unexpected color flashes on export frames
  • Unexpected color flashes on export frames
    Posted by Stephen Kennedy on September 12, 2012 at 6:48 pm
    First time actually rendering out of Davinci Reolve 9 (Lite) and I’m getting all these strange color flashes on quite a few frames here and there.
    Example: frame
    Specs I’m using:
    Macbook Pro 17″
    2.5 Ghz i7
    16 GB 1333 Mhz DDR3 RAM
    Lion 10.7.4
    AMD Radeon HD 6770M 1024 MB
    Is this a hardware issue?
    Anyone else experienced this before? And know how to fix it?!
    Stephen Kennedy replied 14 years ago 3 Members · 3 Replies
  • Eric Johnson
    September 13, 2012 at 8:30 pm
    That looks like potential clipping…. If not, I believe I read on here a while back about throttling down the render speed (you can do that on the screen you set your renders on) and that stuff going away.
  • Gino Amadori
    September 14, 2012 at 6:12 am
    Hi Stephan, I had the same problem with the same computer. It is the AMD video card and the Lion version you have. To correct this I upgraded to Mountain Lion and the problem was solved.
    Hope this works for you too
    Good luck
    Gino Amadori
    Freelance Editor / Colorist
    Google: ginoamadori@gmail.com
    Skype: ginoamadori
    Cell: +(51) 9930-37686
    Lima – Peru
  • Stephen Kennedy
    September 14, 2012 at 6:16 am
    I posted over on Blackmagic’s own forum too and someone recommended the same thing, so I set about downloading and installing Mountain Lion (which was no mean feat down here in the jungle of Ecuador I can tell you).
    It seems to have completely solved the problem.
    Thanks for your responses.
    Cheers,
    S
