Activity Forums Adobe After Effects Expressions Undulating 3D grid
  • Undulating 3D grid
    Posted by Rafael Cruz on January 27, 2009 at 9:01 pm
    On Dan Ebbert’s site there is a great expression for an undulating grid that recreates ocean-like movement.
    Now, I know the code doesn’t really allow for 3D (just a 3D illusion), but I attempted to try and tweak things in order to create a little ocean environment. I have put several hours of work into it but don’t have the know how to achieve the motion of Dan’s undulating grid in 3D space.
    I know that I can create a great ocean environment with Trapcode’s Psunami, but I’m going for a saw-tooth wave kind of thing. i’m looking to make the ocean up out of sketched/scanned/&photoshoped images.
    Any suggestions as to how I achieve this with expressions?
    Michael Sigmon replied 12 years, 7 months ago 3 Members · 3 Replies
  • Dan Ebberts
    January 27, 2009 at 9:23 pm
    This sounds like a perfect job for the noise() expression:
    https://library.creativecow.net/articles/ebberts_dan/noise.php
    Dan
  • Rafael Cruz
    January 30, 2009 at 3:10 pm
    Thanks Dan!
    So simple, and works great. Of course the answer was right under my nose.
  • Michael Sigmon
    February 19, 2014 at 2:21 pm
    Taking Ebberts’ noise() article one step further, turn his expression into a function, place in an external text file, then have each of the elements in your undulating grid comp call that function which returns the [x,y,z] coords for each element. Now you can mess around with the values without having to delete all but one of the layers, change the variable(s), then duplicate 99 or however many times to see how it works.
