Activity Forums Adobe Premiere Pro Undoing deleted sound on the timeline
  • Undoing deleted sound on the timeline
    Posted by David Smooth on August 23, 2015 at 10:18 pm
    Let’s say you drop a video/audio clip onto your timeline, you end up deleting the sound file from the timeline and then nine months and nine hundred edits later you decide you want to reinstate the sound. Is there fast button or function to reinstate the original audio or would I have to track down the original clip in Premiere and re-drop the clip into the timeline?
    David Roth weiss replied 11 years, 1 month ago 2 Members · 1 Reply
  • David Roth weiss
    August 24, 2015 at 12:47 am
    Here’s one way…
    Put you cursor on the first frame of the video clip and hit “F” for Match Frame – this opens the original clip in the viewer with the cursor parked on the identical frame you were parked on in your sequence. If you hit “I” for In Point, you can then drag the clip and it’s audio to the timeline or hit insert or over-record just like a normal edit.
    David Roth Weiss
    Director/Editor/Colorist & Workflow Consultant
    David Weiss Productions
    Los Angeles
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
