Activity Forums Avid Media Composer Undoing Cursor Moves
  • Undoing Cursor Moves
    Posted by Frank Grow on April 7, 2022 at 11:56 pm
    I don’t know how long this has been happening, maybe last year or so?, but it seems whenever I undo an edit, the command z stroke backs me up through every time I’ve moved the cursor since the edit. So now it takes like 18 keystrokes to undo 2 previous edits. I’m pretty sure this wasn’t the case before. Anyone else experiencing this?
    Shahid shahan replied 3 years, 4 months ago 2 Members · 1 Reply
  • Shahid shahan
    April 27, 2023 at 9:31 am
    Hey, frank grow
    It is possible that the behavior you are experiencing when using the “undo” is a result of a software update or a change in the program’s default settings. However, it’s also possible that the issue could be related to your keyboard or computer setup. If you’re experiencing this issue consistently and have ruled out any potential hardware issues, you may want to try adjusting your Avid settings to see if this improves the behavior of the “undo” command. You could also try reaching out to Avid support for assistance in troubleshooting the issue.
    Avid support team link
    https://www.avid.com/support
