Activity Forums Adobe After Effects Undoing a PreRender….
  • Undoing a PreRender….
    Posted by James Purdie on October 25, 2007 at 1:18 pm
    I did a prerender……turning my composition into avi files.
    Is there anyway to go back. In my case I didn’t move the slider bar (which determines how much of the comp you want to render) to the right place. Now the last half of this comp has disappeared. Of course I still have the footage files. But how exactly I altered them, edited, sliced, I can’t recall. The info appears to be all there. Is there a simple way to revert to the original before it was prerendered?
    The Footage was another comp which I had already made. “Reloading the footage” doesn’t allow me to go into the project window to get the comp….
    thanks!!
    James Purdie replied 18 years, 11 months ago 2 Members · 4 Replies
  • Steve Roberts
    October 25, 2007 at 1:51 pm
    That bar of which you spoke sets the length of the “Work Area”, by the way.
    If you made changes to the comp, you can try Undo — AE has multiple Undo.
    Or you could try “revert” to revert to the saved version of the comp on disc.
    Or you could try opening one of the Auto-saved versions if you have it enabled, and if you have a recent version of AE.
  • James Purdie
    October 25, 2007 at 2:27 pm
    Well, the crazy thing is, I turned off autosave a day ago cuz it was irritating me. And somehow my pre-renders got saved into my latest Save version. Undoing is a nogo as well since the program as already opened and closed (actually crashed).
  • Steve Roberts
    October 25, 2007 at 2:35 pm
    I think you have to go back to the last auto-save. There are no other options of which I am aware.
  • James Purdie
    October 25, 2007 at 11:01 pm
    thanks…it’s actually not that bad. I only turned off autosave the day before cuz it was irritating me. MOstly i hadn’t ever played with pre-render. So it was something I didn’t know. I’ve already replaced the prerendered footage in the exact order. However, one strange thing is it now says “several files have gone missing”. Doesn’t seem like anything missing though…hmmm..
