Undo Zoom Tool’s Zoom-in? Restore to view before zoom
Posted by Jill Simpson on February 14, 2009 at 2:39 pmIf I use the zoom tool to select an area of my timeline and zoom-in, after I complete my purpose for zooming in, I want to zoom back out to the exact view I had before. Undo does not do that – undo affects only edits, not view changes.
How can I revert to the previous view (# of tracks, track heights, visible durations, location of indicator/cursor line)?
(This is a repeat of https://forums.creativecow.net/readpost/24/889418, posted Feb 4, for which no reply has yet been received.)
Graham Bernard replied 17 years, 6 months ago 3 Members · 8 Replies -
Linda O’connell
February 14, 2009 at 7:19 pmTry opening up where you made the change in track motion
then right click. There are two places that say restore. I am not sure which one it is, but it is one of them. -
Linda O’connell
February 14, 2009 at 7:23 pmTry opening up where you made the change in track motion
Jill Simpson
February 15, 2009 at 3:32 pmThanks Linda, but alas, the restore options in the “track motion” window don’t affect the zoom level in the timeline.
I have found:
1. If I use the zoom tool on the timeline, but just look without making an edit, a left-click will restore the track heights and time-zoom-level.
2. There is a script “SetZoomLevel” so you can restore back to a preferred time-zoom-level (for example, a one-minute width on the visible timeline).
BUT
I have not found a script or method to restore the track heights.
Jill
Graham Bernard
February 15, 2009 at 5:34 pmTo reset Track Heights to default: Ctrl+’
Any good?
Grazie
Jill Simpson
February 15, 2009 at 6:12 pm“Default track height” is better than nothing, but not what I’ll say we all need. I’m seeking “previous track heights”, since I may have set some tracks shorter than default and some taller.
That said, Ctrl+’ did nothing. I checked “Customize Keyboard” and searched for “track height”, found nothing, then browsed through the results for “track”, and found nothing relevant.
Graham Bernard
February 15, 2009 at 7:38 pm“That said, Ctrl+’ did nothing. ” – Oh really? I’m surprised?
We also have:
a) Decrease height of all tracks – Ctrl+Shift+Down Arrow
b) Increase height of all tracks – Ctrl+Shift+Up Arrow
c) Minimise all tracks – ‘
But, and here’s the thing, and don’t tell anybody else, but . . . if you have, say 3 tracks at different heights and you hit the ‘ they ALL minimise BUT if you hit the ‘ AGAIN, then the tracks go BACK to their previous 3 separate, individual heights.
Grazie
Jill Simpson
February 16, 2009 at 2:17 amI mistook ` for ‘ (back-tick for apostrophe).
Yes, Ctrl+backtick sets all to the same default height.
And yes,
thank you,
backtick minimizes, and backtick again restores tracks’ individual heights – even if I made edits after minimizing.Alas, it’s still not what we surely all could use – zooming in to see details, making an edit or two, then restoring tracks to their individual heights.
P.S. To reduce the number of times I need to zoom in, I added custom keyboard shortcuts: alt-left to go one frame left, alt-right to ….
Graham Bernard
February 16, 2009 at 6:54 amJill, you are most welcome.
We could do with MANY things!
Might I suggest, if you don;t already posses one, and this is concerning your “find” of the frame<>frame editing – yeah?
“P.S. To reduce the number of times I need to zoom in, I added custom keyboard shortcuts: alt-left to go one frame left, alt-right to …. ” Get yourself a Contour Shuttle Pro (CSP) – marvellous!! It does MASSIVE scrubs and Frame by Frame creeps too.
CSP? Wouldn’t leave the house without it!
Grazie
