Activity Forums Adobe Illustrator Undo LZW compression
  • Undo LZW compression
    Posted by Fing Fang foom on April 11, 2007 at 1:29 am
    Hi Y’all
    Is there any way to undo compression? I stupidly compressed (LZW) some tiff files, put weeks of work into them and just realized I don’t want any compression. I’m laying out a book in Photoshop – illustrations and text.
    Can anyone help me or at least tell me the harsh reality that i have to redo all the files?
    Fing Fang foom replied 19 years, 5 months ago 4 Members · 8 Replies
  • 8 Replies
  • Mike Gondek
    April 11, 2007 at 2:55 pm
    You can do a Photoshop Save AS save as back to Tiff and remove the LZW , and your image most likley will still print very good. Many RIPS hang if LZW is on the file, so they may fail to print the file. LZW is a lossy compression though, so you cannot get the quality back you lost.
    There is a filter reduce noise in phothsop which is uspposed to get rif of jpeg artifact, though I have nto had good results with it, you may want to try it on you un LZWed file. Median may also help.
    PSD is a format that has compresison, but is not lossy, I use it all the time as many Adobe apps InDesign/After Effects/Illustrator let you place PSD.
  • Vincent Rosati
    April 11, 2007 at 8:00 pm
    Hey Mike-
    I’ve read the specifications of the LZW algorithm and it states that LZW compression is lossless. I save much of my work in TIFF LZW format, and am concerned by you post.
    Could you elaborate on the lossy attributes of LZW or direct me to some documentation?
  • Mike Gondek
    April 11, 2007 at 8:18 pm
    Vince is right, my memory slippd on that one. LZW is a 100% a non-lossless compression. You should only have to do a save as and uncheck LZW, and your file will be back to original quality.
    Sorry for the scare, but alteast a happy ending.
  • Adolf Witzeling
    April 12, 2007 at 1:52 pm
    Yeah, LZW goes back to the days where computers were struggling with a “50 MB” file. Now computers are so much more powerfull that there’s no reason to use lzw compression any It causes more trouble on some RIPs than there is benefit . I think designers just check that LZW button, because they’ve done it for years this way…just a bad habit 😉
    Adi
  • Vincent Rosati
    April 12, 2007 at 4:13 pm
    I use LZW compression to save disc space. It is not a bad habit, when you can save up to 90% of your disc space by using LZW.
  • Mike Gondek
    April 13, 2007 at 2:02 pm
    Have you tried printing your image as an RGB file. Wanting to make sure you had received my post as it will make a world of difference.
  • Mike Gondek
    April 13, 2007 at 2:04 pm
    my last post wound up under the wrong topic somehow. This was supposed to be a reply to rgb -vs- cmyk. Sorry again.
  • Fing Fang foom
    April 14, 2007 at 4:21 pm
    Thanks a bunch!
