Activity › Forums › Apple Final Cut Pro Legacy › UnDO is not UnDOING??
  • UnDO is not UnDOING??
    Posted by Martin Sterling on June 17, 2005 at 1:22 am
    I am using fcp 4.5 and for some reason, my undo function on certain occasions wont undo. It will do something total wrong like partially erase a clip. the when I hit redo, it wont fix itsself. HELP
    THANK YOU IN ADVANCE.
    Doug Olin replied 21 years, 3 months ago 4 Members · 3 Replies
  • Bouncing Account needs new email address
    June 17, 2005 at 2:52 am
    First thing to always try is to Quit FCP, Restart the Mac, Open your FCP project and try again.
    Next:
    THE FOLLOWING COMES FROM THE KEN STONE WEBSITE:
    “Over 5,000 years ago Confucius wrote: ‘If you are toiling away, you have changed nothing and FCP heads South on you, [starts behaving in strange ways] then it is time to trash your FCP Preferences.’ ”
    Click the following link for instructions on how to do this.
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    Another method is to use “FCP Rescue” a free Apple Script that will Trash the Preferences for you (and restore nearly all of your user settings afterward).
    There are versions for FCP & FCE.
    Download these free Apple Scripts at
    https://fcprescue.andersholck.com/
  • Annaël Beauchemin
    June 17, 2005 at 6:18 am
    I recently discovered this bug too. On my system it happens when I switch keyboard layout in the keyboard input menu.
    I do this often when I work in AfterEffects in conjunction with FCP… I must use the US layout for aftereffects to use all the nice shortcuts. Flushing prefs doesn’t change anything.
  • Doug Olin
    June 20, 2005 at 12:42 am
    I had this problem several weeks or months back. When I tried to use undo, it would separate linked clips and toss the fragments around the timeline. It made for very messy editing for a while. I trashed render files that were associated with the timeline and that seemed to clear it up. Undo works fine now.
    Doug Olin
    Pensacola Christian College
    G5 DP 2.0, 2 GB RAM, FCP HD, IO, OS 10.3.9, Medea RT3X 1200 GB
