Activity Forums VEGAS Pro undo create multicamera track
  • undo create multicamera track
    Posted by Mike Thompson on February 18, 2010 at 4:55 pm
    When I create a multicam track, the old video tracks disappear.
    How do I get them back? Say if I want to manipulate the color on one of them later on, how do I retrieve the track from the multicam edit?
    Also, why does this forum not require a password? Is that secure?
    John Rofrano replied 16 years, 2 months ago 5 Members · 7 Replies
  • 7 Replies
  • John Rofrano
    February 18, 2010 at 9:23 pm
    You don’t. It’s one way only.
    Apply the color correction to the Media in the Project Media pool. This will affect it on whatever track it happens to be on.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Stephen Mann
    February 20, 2010 at 1:23 am
    Duplicate the tracks before you create the multitrack.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Mike Thompson
    February 20, 2010 at 11:26 am
    Thank you, those are sensible work arounds. I also save the project as a unique filename just before the seemingly destructive ‘create multitrack’ operation.
    When I switch to a different camera, it obviously creates a new event in the timeline. At the moment the default is a straight cut from one cam to the next. IS there a way to set the default as a fade/merge instead? Like over 1 second? Sorry I don’t know the technical terms.
    Or are fades a bit naff? I don’t see them on TV much, but equally I don’t like the jerkiness of a simple cut, even if it’s in time to music! Thanks for any tips
  • Mike Kujbida
    February 20, 2010 at 12:41 pm
    “IS there a way to set the default as a fade/merge instead?”
    In a multi-camera editing project, you can automatically apply crossfades to your cuts. To do so, hold the Ctrl key while you click the camera feed to call a shot. This creates a crossfade instead of a cut, with the alignment and duration determined by the Cut-to-overlap conversion settings from the Editing tab of the Preferences dialog.
    This tip is from the Q&A section of the recent Vegas Pro 9 webinar.
    It’s full of useful tips and is well worth reading.
  • Luis Cosme
    July 9, 2010 at 2:10 am
    Same scenario here and I need help.
    I had video track 1 and track 2.
    I know I needed to color correct track 2 from the second camera but I figured I would go back after doing the multicamera edit (like I do in Premiere) and apply the color correction to the entire track 2.
    Well…., Track 2 seems to be gone for ever! 🙂
    Instead of adding the plug-in to each and every clip. Is there a better way to do it?
    This is a 45 minute video and has a countless number of cuts.
    Thanks in advance for your help.
    -Luis-
  • Luis Cosme
    July 9, 2010 at 2:18 am
    ok I just read the part about adding the color correction to the pool. Let me try to figure that out and do that to see how that works out.
    thanks
  • John Rofrano
    July 9, 2010 at 3:13 am
    The easiest way is to right-click the event and select Media FX… from the context menu.
    ~jr
