Activity Forums Avid Media Composer Undo at Bin level
  • Undo at Bin level
    Posted by Olivier Prudhomme on September 12, 2014 at 5:50 pm
    can we finally undo an action at the Bin level like… deleting the wrong sequence without having to go back to the Attic?
    or are we still walking on thin ice while working in the bin
    Alain Dessauvage replied 12 years ago 3 Members · 3 Replies
  • Shane Ross
    September 12, 2014 at 6:08 pm
    Thin ice. Change a file name? Delete a clip or sequence…tough noogies. Annoying as hell.
    Shane
    Little Frog Post
  • Olivier Prudhomme
    September 12, 2014 at 6:14 pm
    this is bad news….
    I know the attic’s there but when you work under crazy deadlines and that you need to move super fast… accidents happen and losing a sequence can be devastating as you can’t always rely on the attic… unless we autosave every 1 min…..
  • Alain Dessauvage
    September 14, 2014 at 9:35 pm
    Honestly, I think it’s very useful that Avid doesn’t undo bin events. After all, how many times do you delete a sequence by accident ? You also need to confirm the delete, so this only happens if you’re very distracted. And the attic is very reliable.
    What happens more often though, is the following situation which you no doubt already experienced. You’re doing some modifications and tryouts on an edit. Suddenly the director asks you if you’ve saved the previous version, which of course you haven’t. No problem, you just duplicate the edit in the bin and then undo all the modifications you have up to this point. So now you have two versions: the original and the modified one.
    If Avid would undo bin events (like FCP), the only way to achieve this would be to undo your modifications, then duplicate the sequence, and then redo all modifications after having first memorized them. Not very practical..
    Also, excluding bin events allows for an uncluttered and clear undo list.
    Maybe it should be an option, like the ‘undo only record monitor events’ toggle which I also have enabled.
    https://www.imdb.com/name/nm0220918/
