Activity Forums Adobe After Effects Undo a Pre-Comp
  • Undo a Pre-Comp
    Posted by Todd In arizona on October 13, 2007 at 4:30 pm
    I precomposed a group of layers then did some time remapping to that pre-comp layer. Exported the file and noticed some things I wanted to change back in the original layers.
    Can I “open” the pre-comp and make changes in the original layers without having to undo all the changes and edits I made to the pre-comp layer? I’d like to preserve all I did to the pre-comp, and would hate to lose all that work just to make one little change to an original layer.
    Thanks much.
    Todd
    Stephen Pusser replied 12 years, 1 month ago 5 Members · 4 Replies
  • Mike Clasby
    October 13, 2007 at 6:12 pm
    Select the layer, Right-Click > Open Composition
  • Todd Kopriva
    October 17, 2007 at 4:56 am
    Yes, you should be able to just open the precomposition, make whatever tweaks you want to the component layers, and retain the changes that you made to the precomposition layer (as long as you didn’t change timing in the precomposition or something like that).
    To open a precompositon, Alt+double-click (Windows) or Option+double-click (Mac OS) the precomposition layer.
    For this and more information on working with precompositions, see the “About nesting and precomposing” section of After Effects Help.
    Todd Kopriva, technical editor, Adobe Systems Incorporated
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    How about taking a survey about After Effects documentation? Please?
  • Stephen Pusser
    July 24, 2014 at 1:18 pm
    Is there anyway to undo a pre-comp? I have a project in which I pre-comp’d layers and now I have decided that I want to parent other layers to layers within the pre-comp. No biggie if I can’t, but it would make it easier if I could.
  • Michael Szalapski
    July 24, 2014 at 4:47 pm
    https://aescripts.com/un-precompose/
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
