Activity › Forums › Adobe After Effects › Undistort 360 video
  • Undistort 360 video
    Posted by James Buckle on August 19, 2022 at 4:26 am
    Hello! Hoping someone can help me, is there any existing effect or 3rd party plugin in AE that will help me undistort this 360 footage of a bridge so there arent curved lines and it looks more like a wide panoramic shot. I am hoping to stretch it out to go across multiple screens and look more flat (think spherical world globe being flattened to look like a normal world map) see cityscape panorama image for desired effect
    Pierre Jasmin replied 4 years ago 3 Members · 4 Replies
  • Walter Soyka
    August 19, 2022 at 5:19 pm
    You can use either the built-in VR Sphere to Plane effect (2D, with camera controls built into the plugin), or the built-in CC Environment effect (3D, responsive to the comp camera).
  • James Buckle
    August 25, 2022 at 1:22 pm
    Hey Walter thanks for the Reply.
    I tried both these methods but didnt achieve the desired result. I would still like to keep the 360 wideness of the shot but remove the distortion from above and below the horizon line. any thoughts?
  • Walter Soyka
    August 25, 2022 at 5:21 pm
    Use CC Environment in an extra-wide comp. Use a wide FOV for the camera. Tweak the Lens Distortion parameter in CC Environment. You can do some additional manual distortion correction with the Bezier Warp or Mesh Warp effects.
  • Pierre Jasmin
    August 25, 2022 at 8:17 pm
    Flor 3rd party, you can try RE:Lens from http://www.revisionfx.com
    That would be the plug-in FromLatLong within the package if I understand your question.
    Pierre
