Activity Forums Panasonic Cameras Underwater Footage
  • Underwater Footage
    Posted by Pipito on November 2, 2006 at 4:57 pm
    Just finished reviewing my underwater footage. The water clarity unforfunately was not that good
    Set the cam with OIS 1080i60i /Video cam/ F6 and still noticing small shift, jumps in the video while panning.
    It is very annoying because you never know when will you get them. I could set OIS off, but then how stable will the picture be?
    At this point i don’t know if i should sent the camera back unless i hear from you guys that you are seeing the same problem and live with it.
    talked to panasonic support. he told me to try recording 720 60p. instead of 1080i60i. 720 has much better resolution.
    Will see what happens.
    thanks,
    Felipe
    Pipito replied 19 years, 10 months ago 2 Members · 3 Replies
  • Pipito
    November 2, 2006 at 10:42 pm
    Recorded in 720 60p mode. dame problem. Small vertical shifts while panning handle. I had the 100A for 3 years know i never saw this problem.
    pipito
  • Barry Green
    November 7, 2006 at 9:56 pm
    The jumps in panning are due to the OIS. Turn it off.
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
  • Pipito
    November 7, 2006 at 11:13 pm
    I can turn it off and maybe underwater the movements will be smooth, but if i shoot handheld not underwater with the OIS on i still see them and that is a problem if i take it off then it will be too shaky and i don’t want to be carrying always a tripod.
    felipe
