Activity Forums Adobe Premiere Pro Understanding Project Setting?
  • Understanding Project Setting?
    Posted by Troy Smith on September 1, 2008 at 7:59 pm
    HI,
    My Last post may have been confusing,
    I’ll try put it simply here,
    If one sets up a project as editing mode Desktop,
    what is the internal bit depth 8 or 10 bit?
    and is it 4:4:4 RGB or 4:2:2 or 4:1:1
    I can’t seem to find the answer to this on adobes website.
    Regards
    Troy Smith
    Jeff Pulera replied 18 years ago 2 Members · 1 Reply
  • Jeff Pulera
    September 2, 2008 at 1:58 pm
    When starting Premiere and choosing an editing mode, click the Custom Settings tab, then “Video Rendering”.
    You will have options for “File Format” and “Compressor”. If you poke around looking at the various available options, some show the bit depth, for instance 4:2:2 YUV. Some are uncompressed, etc., depends on your needs.
    What kind of source material are you working with, and how do you wish to deliver?
    If working with DV or DVCAM captured via 1394 then you’re dealing with 4:1:1 color for NTSC, or 4:2:0 for HDV natively.
    Jeff Pulera
    Safe Harbor Computers
    http://www.sharbor.com
