Activity Forums Adobe Media Encoder Understanding Hardware Impact on AME performance
  • Understanding Hardware Impact on AME performance
    Posted by James Malamatinas on February 5, 2015 at 5:04 pm
    My PC specifications are below.
    Core i7 2nd Gen Processor
    16GB DDR3 RAM
    Nvidia 570 GTX graphics card
    Samsung 840 Pro 256GB SSD (Program Files)
    OCZ Vector 128 GB SSD (Scratch Disk)
    I’m trying to encode Canon 7D files into h.264 using Vimeo recommended (max bit rate @ 12) settings and I see the following hardware characteristics:
    – CPU is 95-100% maxed out at all times
    – RAM is hugely under-utilised at only 5GB of 16GB being used.
    – SSD drive is nowhere near maxed out
    I was pretty surprised that so little RAM was being used and that the CPU was such a limiting factor and I therefore want to better understand why the CPU is the bottleneck and how the encoding uses each of the main hardware components so that I can better comprehend the relationship between encoding and hardware.
    Could anyone recommend some basic resources I should start out with or useful sites with this kind of content?
    Thanks.
    Tero Ahlfors replied 11 years, 7 months ago 2 Members · 1 Reply
  • Tero Ahlfors
    February 6, 2015 at 8:59 pm
    Here’s a simplified breakdown. If you’re decoding/encoding compressed formats (like h264, mpeg2) it will need CPU power because pretty much all your computer is either reading the data from small file to show it to you or making a bigger file smaller. SSD or a RAID won’t help that much unless your CPU’s can output that stuff really, really fast. If you’re dealing with lossless formats (DPX, TIFF etc) then a fast hard drive will help because there’s less computing and straight up more writing going on. Especially when you are reading lossless stuff a fast hard drive is essential.
