Activity Forums Maxon Cinema 4D Understanding Computer Hardware & C4D
  • Understanding Computer Hardware & C4D
    Posted by Ryan Scammell on November 11, 2021 at 7:17 pm
    Hi all,
    Every time I start looking at getting a new computer, I’m reminded that I don’t totally have a grasp on which physical parts of the computer most effect which part of the C4D experience. It’s really important to understand this so you/we can make informed decisions about how best to direct our money when buying new equipment. So I wrote to maxon to get a little insight and here were their responses:
    – What component most effects viewport speed?
    The viewport is mainly handled by the GPU. Still, if you are running simulations, this falls on the CPU, so you can potentially get bottlenecked by the CPU; my rule of thumb, especially if you are GPU rendering, is to get a faster single-core GPU to handle the simulations, hair, particles, etc., so you don’t get bottlenecked. (Note: Ronald from maxon wrote “faster single-core GPU” above but I think he may have meant “faster single-core CPU)
    – What about processing physics/cloth simulations?
    Simulations are CPU and single-threaded, so again having a good single core speed will help, and depending on the simulation, having a good amount of RAM to write to will help. I can not give specific numbers because there are so many variables, but a fast single-threaded CPU and a good amount of RAM go along with simulations.
    – What about particles?
    X particles may be handled differently than native Cinema 4D particles, so I would contact Insydium on how they handle the particles, but native Cinema 4D particles are a simulation, and I refer you to the answers above.
    – High numbers of polygons?
    Polys fall under what the viewport would require, which is the GPU, now; if you have a ton of objects, this may require, again, a faster single-core speed because the object manager uses the CPU and if you have a large number of objects in the scene you can potentially get bottlenecked. Cinema 4D handles a large number of polygons really well, but if you have many objects and things get slow, I recommend connecting and deleting where you can to optimize things.
    (For me, since I do almost exclusively GPU rendering, the big takeaway is that spending my money on lots of CPU cores may not have much benefit and it’s better that I focus on CPUs specifically with higher clock speed even if they have fewer cores.
    Big thanks to Ronald from Maxon for taking the time to go through this with me.)
    Steve Bentley replied 4 years, 9 months ago 2 Members · 1 Reply
  • Steve Bentley
    November 12, 2021 at 7:02 am
    A couple of things to keep in mind. If the scene is large it may not fit in the GPU ram and then it just won’t render, so back you go to CPU rendering which usually has more machine ram to use and disk swap space – in theory, it’s unlimited.
    If you pole the guys on the web who use C4D professionally I think you will find a lot of threadrippers – so that means more and faster CPU cores. Now to be fair, those who can afford threadrippers generally have a few GPU’s chained together too. And while they are doing a huge amount of their rendering on GPU they are still relying on that threadripper a significant amount. And that can’t be a coincidence (or a waste of money). There are also limits to how many GPU’s you can tie together efficiently.
    Depending on your render engine you may also find that due to sampling and customizing the render engine for the task, the CPU engine will run faster, even though it has fewer buckets to throw at it. And check the denoiser you might be tempted to use – it may engage the CPU even at the end of a GPU run. The denoiser can take longer than the render.
    Some of the third party engines are both GPU and CPU but a few of them aren’t
    really mature yet in the GPU category. In the trade GPU is often used
    for look/dev and then the file is thrown against a bunch of CPUs for
    final output.
    The standard and Physical engines both use the CPU so again, seeing lots of buckets will depend on how many threads your CPU has. And there is nothing wrong with these engines. They have gotten a bad rep because they don’t have a progressive mode that is so helpful in look/dev. But they are excellent render engines and can render stuff realistically if you know what you are doing.
    There are also some issues with flavors of GPU’s and depending on platform (like Mac) you may be stuck using CPU for what you need (and this also depends on what render engine you pick). There’s also compatibility issues with open GL versions and Open CL. A modern Nvidia should have no issues, but an older one or an AMD might run you up against a brick wall on the GPU side of things. Not saying they will, it’s just your chances are higher for an incompatibility issue. Also consider what your compositing engine uses – might as well have a machine that does both well.
    Coding for iterative and recursive sims (like evolving particles) is really hard on a GPU at the moment so I could guess that Indsydium is CPU weighted – the render might not need to be but the simming part will be I’ll bet.
    Ironically, the answer usually comes down to budget rather than what is going to be best. Threadrippers aren’t cheap and multiple GPUs can set you back as well. Building the “ideal”machine can break the bank so you often need to shoot for a cheaper “sweet spot”. Consider also smaller cheaper machines on a network that can work on the frames you are working on simultaneously to give you faster response times. More, cheaper CPU’s spread around can often be cheaper per core than one big monster.
    Let us know what you end up with.
    (I love the “faster single core GPU” from Maxon. By “single”, do you suppose they mean “thousands”? I think you are right in your assumption there)
