Activity › Forums › Adobe After Effects › Under water
Under water
Posted by David Gilhooly on August 16, 2005 at 10:28 amDoes anyone know if there is a plugin or an effect that i can use in After Effects 6.5 that would give the under water effect?
thanks
James Simpson replied 21 years, 1 month ago 3 Members · 4 Replies -
Aharon Rabinowitz
August 16, 2005 at 1:13 pmDisplace > Wave Warp
If you mean underwater seen from above the surface, then a combonation of Simulation > wave world (To create a wave displacement map) and Simulation > Caustics (to create the water’s specular surface and distortion, as well as underwater caustic lighting.
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com -
Aharon Rabinowitz
August 16, 2005 at 6:34 pmTry Distort > Waveworld.
Aharon Rabinowitz
James Simpson
August 17, 2005 at 6:29 pmHi there,
I would try Digital Anarchy’s Psunami, it’s awesome. There is a tutorial on their website explaining how to do an underwater shot. Hope that helps.Cheers,
Jim
