Activity Forums DaVinci Resolve Under ‘Mark’ the Keyframe options are greyed out?
  • Under ‘Mark’ the Keyframe options are greyed out?
    Posted by Nigel Cooper on December 5, 2020 at 10:10 pm
    In paid for version of Resolve if I click ‘Mark’ at the top the Keyframe options are greyed out i.e. Add Keyframe, Add Static Keyframe etc, see image. It’s a drag as I add loads of keyframes for the audio volume to get volume to go up and down at certain points and I have to move the mouse over and click the tiny keyframe symbol each time, keyboard shortcut would be much quicker and easier but the keyboard shortcut does not work as Add Keyframe is greyed out and does not work. Suggestions?
    Nigel Cooper replied 5 years, 8 months ago 2 Members · 2 Replies
  • David Baud
    December 5, 2020 at 11:15 pm
    The keyframe functions under MARK menu refer to the Color page (keyframing a node or keyframing tracking) not the audio keyframes. In general, I found the main menus confusing because some functions apply to certain pages and not others, but they still show up there, just like your example.
    In Resolve 16, I believe your only option in the EDIT page is to move the audio keyframes with the mouse. If you go to the FAIRLIGHT page and select the Inspector tab, you can move from one keyframe to the other using < or > in front of the volume, and change your value at the same time.
    I hope this help.
  • Nigel Cooper
    December 6, 2020 at 12:08 am
    Makes sense, David, and thanks for the input. Yes, confusing that the main menus simply grey out things that only work in other pages, they should just disappear altogether to save the confusion, I’m sure BM coders can work that one, just have them invisible instead of greyed out.
    Fairlight page thing does not help. I need a fast keyboard shortcut for adding a keyframe to the audio track at the point where the playhead is. Anybody?
