Activity › Forums › Adobe After Effects Expressions › Undefined Value Used In Expression; Require assistance with Start Time Stop If Else Statement Wiggle But Keeping Same Aspect Ratio.
  • Undefined Value Used In Expression; Require assistance with Start Time Stop If Else Statement Wiggle But Keeping Same Aspect Ratio.
    Posted by Kyle Balitz on August 27, 2019 at 2:35 am
    Hello, I am trying to figure out an expression of using a Start and Stop time If Else statement using Wiggle. But I need to maintain the aspect ratio of the wiggle.
    I tried to use the following syntax:
    timeToStart = 6;
    timeToStop = 16;
    if ((time > timeToStart) && (time < timeToStop))
    { w = wiggle(5,10);
    if (value[0]===0){[0, w[1]];}
    else{[w[0], w[0]*value[1]/value[0]];};
    But get an error that say Undefined Value used in expression (could be out of range array subscript?) at the
    timeToStart = 6;
    Could anyone help assist me on the correct syntax for this so I do not get this error. This maybe have to do with the update in After Effects 2019.
    timeToStart = 6;
    timeToStop = 16;
    if ((time > timeToStart) && (time &lt; timeToStop))
    { w = wiggle(5,10);
    Kyle Balitz replied 7 years ago 2 Members · 2 Replies
  • Dan Ebberts
    August 27, 2019 at 4:08 am
    You didn’t define what’s supposed to happen outside the start and stop zone. Try replacing the last line:
    with this:
    }else value
    Dan
  • Kyle Balitz
    August 27, 2019 at 5:38 pm
    Wow Dan, that fixed it. Thanks for all the work you guys do here!
