Activity Forums Panasonic Cameras Uncrack the 720p 50fps
  • Uncrack the 720p 50fps
    Posted by Dennis Yeung on February 23, 2007 at 5:23 am
    Hi
    I shoot some footage in DVCPRO HD 720p 50fps, when i grab into FCP and Avid, its run in normal speed, not high speed, can some one help me?
    Dennis
    Uli Plank replied 19 years, 7 months ago 3 Members · 2 Replies
  • Accountneedsrealnameupdate
    February 23, 2007 at 7:14 pm
    I guess since no one else had responded, I’ll at least tell you what I know. I assume you’re in a PAL country and shot 50 with the intent of playing it back at 25 for a 2X over crank effect. I also assume that the process is the same as 60/30 in NTSC, which is what I’m basing my answer on. If you just choose 60P as your recording format, and bring it into a 60P Avid project, it will play at 60P, or normal speed. If you want to shoot 2X over, you need to go into the Recording Setup menu and select 720/30P (or 720/25P), now go into the Scene File menu, select Film Cam for Operation Type and then set the Frame Rate to 60, (50). You will now have a 30P clip shot at 60P, so when you bring it into a 30P project in Avid, it will play at 30, or half speed, which I assume is what you are trying to do.
    What I do not know is how to bring a clip shot at 50/60 into a 25/30 project. I’m hoping someone else here might be able to help out as I would like to know myself.
  • Uli Plank
    February 24, 2007 at 6:14 am
    This site might help (it’s in German, but the related PDFs are in English):
    http://www.aulich-adamski.de
    Regards,
    Uli
    Author of “DVDs gestalten und produzieren”, a book on professional DVD-authoring in German.
