Activity Forums VEGAS Pro Uncontrolled Loopping At Start Of Timeline
  • Uncontrolled Loopping At Start Of Timeline
    Posted by Sprague Theobald on June 24, 2008 at 5:10 pm
    I’ve got a weird occurance the cause of which I’m not sure is because I’m doing something wrong or it’s a glitch. Several times now I find that my cursor jumps back to the beginning of the time line and when I hit play it seems to loop the first 2 or 3 frames over and over again. This looping happens about 3 or 4 times a second. When this happens I can’t seem to get it to play the full time line. I’ve tried shutting the program down but to no avail. It happens so infrequently I can’t remember how I solved the problem in the past. Sorry I can’t be more precise in describing what is happening, I don’t quite understand it well enough to explain it! Any thoughts?
    As usual, many thanks in advance.
    Sprague
    Vegas Pro.8
    Sprague Theobald replied 18 years, 2 months ago 5 Members · 12 Replies
  • 12 Replies
  • John Rofrano
    June 24, 2008 at 5:41 pm
    It sounds like you have a very small timeline selection at the start of your project. Try turning looping off and make a selection somewhere else on the timeline and it should go away.
    ~jr
    https://www.johnrofrano.com/
  • Sprague Theobald
    June 24, 2008 at 6:08 pm
    Hi John,
    Thanks for getting back to me. I just shut the computer off and re-booted and that seemed to clear it. I seem to remember that if I made a selection say 2 minutes down the time line, the cursor would snapback to the start even with looping turned off, “seem” being the operative word. If it happens again I’ll do as you suggest.
    Sprague
  • Allen Zagel
    June 24, 2008 at 9:45 pm
    Look at the bottom of the timeline to the left, next to the red circle. You’ll see a circular line with an arrow. Make sure that’s not pushed in. That’s the ‘looping’ feature that will loop whenever you have a selection made.
    Like John says you may have a small area selected. Vegas will remember that when you shut it down and open it again, so you got to unselect it and clear the loop feature first.
    Allen
    ASX Media Group, Inc.
    https://www.asxvideo.com
  • Kert
    June 24, 2008 at 11:29 pm
    Go:
    Options->Preferences->General and check:Make Space Bar & F12 Play/Pause instead of Play/Stop
    Your courser will not jump to where you have started.
    jk
  • Sprague Theobald
    June 25, 2008 at 11:42 am
    Thanks all! Great suggestions, great product, great community!
    Sprague
  • Sprague Theobald
    June 25, 2008 at 2:33 pm
    Hi guys,
    It’s done it again. I’ve checked for any small bit of unseen media – none. I’ve turned off the looping feature – still does it. I think it’s a glitch as when I go to scroll down through my Project Media clips it snaps right back to the 1st clip. Any thoughts?
    Thanks again,
    Sprague
  • Terry Esslinger
    June 25, 2008 at 6:33 pm
    What do you mean by “scroll down through my media clips” and how do you do it?
  • Sprague Theobald
    June 25, 2008 at 11:43 pm
    Hi Terry,
    I’m not at my computer now but will try to explain. Apart from the weird looping on the time line, if I go to the slider on the right side of the box that holds my project clips in their assigned files (“Music”, “B-roll”, “Gfx”, etc) and drag it to the bottom of the box to look at the clips, when I release the slider is shoots right back up to the top, not allowing me to select a clip, graphic, etc. If my description doesn’t make sense to you I’ll post again tomorrow morning when I’m in front of my screen and describe it in better detail.
    Sprague
  • Terry Esslinger
    June 26, 2008 at 4:38 pm
    I think I understand what is happening and thats a strange one. Does it happen in any other apps besides Vegas?
  • Sprague Theobald
    June 26, 2008 at 7:58 pm
    Nope, just seems to be Vegas.
    ST
