Activity Forums Apple Final Cut Pro Legacy uncompressed throughput
  • uncompressed throughput
    Posted by Jeff Griffiths on February 20, 2007 at 1:43 pm
    Hi- Im editing uncompressed footage and having a hard time getting the sequence to play without choking. I have only 1 layer ov video, 1 stereo pair of audio. Warning of “frames were dropped…” MacG5 1.8DP 1TSATA AJA LA i/o Seems like this is not too much to ask of the machine. Any ideas about how I can get this to go?
    David Roth weiss replied 19 years, 6 months ago 5 Members · 8 Replies
  • 8 Replies
  • John Pale
    February 20, 2007 at 2:23 pm
    I have read that some AJA users have to put their PCI cards in specific slots. Give AJA a call, as their website may not be updated with the most current info.
  • John Pale
    February 20, 2007 at 2:24 pm
    Oh….just saw you were on a G5, but I still think its worth a call to AJA.
    You are entitled to free tech support from them, and they are always helpful.
  • Shane Ross
    February 20, 2007 at 3:20 pm
    Also, where is your media stored? You didn’t mention that.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Jeff Griffiths
    February 20, 2007 at 4:13 pm
    The media is stored on a striped RAID with 4 Hitachi 250GB drives. I’ll check in with Hector at AJA. I agree, they do have excellent support.
  • Gary Adcock
    February 20, 2007 at 4:35 pm
    [Shane Ross] “Also, where is your media stored? You didn’t mention that.”
    nor what kind of uncompressed footage. SD, HD 8bit , 10bit, what frame rate.
    all of those are important too.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
  • John Pale
    February 20, 2007 at 4:39 pm
    If you are using SD Uncompressed, your system should be able to handle that. Hopefully AJA can help…sounds like a possible PCI bandwith issue with slot order, but they would know for sure.
  • Jeff Griffiths
    February 20, 2007 at 4:40 pm
    Sorry- The camera master is SD Mini DV. I digitized it through component to 8 bit uncompressed SD NTSC 29.97 fps.
  • David Roth weiss
    [Jeff Griffiths] “The media is stored on a striped RAID with 4 Hitachi 250GB drives.”
    The 4 drive raid has plenty of throughput for uncompressed SD, but not HD. You didn’t say which flavor you were cuttting.
    DRW
