Activity › Forums › Apple Final Cut Pro Legacy › Uncompressed quality with spacesaving compression?
  • Uncompressed quality with spacesaving compression?
    Posted by Mike Johnson on May 10, 2006 at 10:39 pm
    I’ve various 4:2:2 footage, DVCPro 50, Digibeta, etc.
    I have a Quad G5 and this week I’m going to buy the Kona LHe card.
    I’m going to start to capture thru SDI, and I’m thinking of using some of the Uncompressed codecs.
    My question is how do I get maximum quality from my tapes and still use as little HD space as possible?
    A capture at around 10 MB/sec would be nice.
    Are there any non destructive uncompressed codecs that will work with my setup to be?
    If I go 8 Bit uncompressed the filesize will be around 20 MB/sec?
    What are my options?
    Nick Meyers replied 20 years, 4 months ago 6 Members · 6 Replies
  • Walter Biscardi
    May 10, 2006 at 11:36 pm
    [Mike Johnson] “Are there any non destructive uncompressed codecs that will work with my setup to be?
    What are my options?”
    Your options are 8bit and 10bit Uncompressed if that’s what you’re trying to do. Yes, 8bit is around 20MB/s and 10bit is around 30 – 40MB/s.
    Uncompressed is uncompressed. If you want options, then you look at compressed codecs like DV50, DV, DVCAM, Motion JPEG, etc…
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Oliver Peters
    May 11, 2006 at 12:17 am
    Though not uncompressed, I’ve had good luck with DV50. It’s 4:2:2 at about 3:1 compressed. Fine for corporate/industrial, dealer sales videos, local spots, etc.
    Sincerely,
    Oliver
    Oliver Peters
    Post-Production & Interactive Media
    Orlando, FL
    http://www.oliverpeters.com
  • Jeremy Garchow
    May 11, 2006 at 3:11 am
    Supposedly Photo Jpeg at 75% is really sweet, but there’s no r/t effects. Apparently, there’s a way to hack FCP to enable Photo Jpeg r/t, but I don’t know the code.
    You should look at Sheer Video as they have a codec that’s supposedly uncompressed at a fraction of the bandwidth, but there’s no r/t there either as Apple, for some reason, wants to hold the codec reigns tightly.
    Jeremy
  • Nick Meyers
    May 11, 2006 at 7:14 am
  • John Fishback
    May 12, 2006 at 11:54 am
    Anyone know if this is doablein FCP5?
    John
    Dual 2.5 G5 4 gigs RAM OS 10.4.3 QT7.0.3
    Dual Cinema 23 Radeon 9800
    FCP Studio 5 (FCP5.0.4, DVDSP4.0.2, Comp2.0.1, STP1.0.2)
    Huge U-320R 1TB Raid 3 firmware ENG15.BIN
    ATTO UL4D driver 3.50
    AJA IO driver 2.1 firmware v23-28
    SonicStudio HD DAW, Yamaha DM1000, Genelec Monitors
  • Nick Meyers
    May 12, 2006 at 2:57 pm
    the post is less than a year old, so it may well be referring to FCP5.
    try it.
    he does recommend making a back-up so you can always go back.
    nick
