Activity › Forums › Apple Final Cut Pro Legacy › uncompressed QT – problem with fields
  • uncompressed QT – problem with fields
    Posted by Rachel Reupke on June 18, 2008 at 9:20 am
    I am trying to convert a dv pal video (originally made in after effects as a composite of dv footage and photoshop stills) into an uncompressed 8-bit quicktime file for the best quality projection from a laptop.
    The stiller parts of the image appear super-sharp, much better than the original, but I don’t know how to get rid of the interlacing seen on the fast moving video elements.
    I’ve tried both changing the sequence settings to uncompressed QT and exporting from a dv pal sequence (with progressive scan option) using quicktime conversion to uncompressed QT with the deinterlace option on, but this looks no better than dvpal.
    Any suggestions?
    Thanks in advance!
    Rachel
    Rachel Reupke replied 18 years, 3 months ago 2 Members · 2 Replies
  • Fred Miller
    June 18, 2008 at 1:35 pm
    You might want to try JES Deinterlacer. Just google it. It’s a little program that does format conversions, among other things. And it’s pretty easy to learn.
    FCP Studio 2
    Dual 3Gg Quad Core
    5Gg RAM
    KONA 2
    OS 10.4.11
  • Rachel Reupke
    June 18, 2008 at 5:35 pm
    Thank you – that’s made a big improvement.
