Activity Forums Compression Techniques Uncompressed QT file won’t play on PC?
  • Uncompressed QT file won’t play on PC?
    Posted by Chris Rowe on December 1, 2006 at 1:00 am
    I’ve been asked to create a 10 bit uncompresssed QuickTime file which will be submitted for broadcast.
    No big deal (I thought) as this is clearly an option in QT PRO.
    I made the file with no problems and it worked fine on a Mac.
    As part onf my routine testing, I also check my encodes on a PC. Guess what? No Video, just black. Audio seems fine. I would suspect a missing codec, but with an uncompressed file, I thought that there was not any codecs, just QuickTime.
    Should this file play on a PC?
    BTW, Both Mac and PC are using QT 7
    I’ve also tried making the file in compressor and get the same results.
    I have Squeeze 4.3, but did not try it as uncompressed did not appear to be an option.
    Any help is appreciated in advance.
    Chris
    Chris Rowe replied 19 years, 9 months ago 2 Members · 4 Replies
  • Charles Simonson
    December 1, 2006 at 5:23 am
    Yeah, just download the BlackMagic or AJA codecs for Windows, install them, and you should then be able to play back the 10bit QTs.
  • Chris Rowe
    December 1, 2006 at 5:24 pm
    Hi Charles,
    What do you mean by yeah?
    Yeah, it should not work? Yeah, your not suprised at my results?
    I was under the impression that an uncompressed file would not need a codec to play as it is not compressed. Should’nt QuickTime just be able play this file on it’s own (Mac or PC)?
    Thanks for the help
    Chris
  • Charles Simonson
    December 1, 2006 at 6:29 pm
    Yes, as in it should play back on a PC. 8bit uncompressed files generally aren’t a problem, but 10bit can be, and I imagine you used the Apple 10bit Uncompressed codec when exporting, which only gets installed with FCP. So on a PC, you need to download and install a compatible codec, like BlackMagic.
  • Chris Rowe
    December 1, 2006 at 6:36 pm
    Hi Charles,
    Thank you. You gave great advice.
    I downloaded BlackMagic’s codec and it tested fine on the PC.
    I’ll include the codec for my client just in case.
    Best regards,
    Chris
