Activity Forums Adobe Premiere Pro Uncompressed files
  • Uncompressed files
    Posted by Robert Massoud on August 29, 2005 at 10:45 pm
    Is there anyway that you can capture uncompressed files in Premiere pro 1.5 ? Do you need a capture card ? and what kind of interface would it have to be ?
    Robert
    Redgum replied 21 years ago 5 Members · 5 Replies
  • Steven L. gotz
    August 29, 2005 at 10:53 pm
    Uncompressed files from what? If you are getting video from a MiniDV camera, then the firewire capture is simply a file transfer and is as good as it gets. You can then dowhatever you want with it.
    If you mean HDV captured via component outputs live, before it goes to tape, that is a different matter.
    Steven
    Adobe Premiere Pro 1.5.1 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Baz Leffler
    August 30, 2005 at 12:52 am
    Yes. Its called Decklink; but that is assuming the original isn’t compressed to start with
  • Redgum
    August 30, 2005 at 5:27 am
    And all video camera footage is compressed!
    Redgum Television Productions
    Broadcast & Corporate Documentaries
    Brisbane, Australia
  • David Farland
    August 30, 2005 at 5:55 am
    Not quite….
    The live component output of the sony Z1/FX1 doesn’t use the camera’s MPEG2 encoder(compressor).
    Dave Farland
  • Redgum
    August 31, 2005 at 1:57 pm
    Sorry David, I should have added “when committed to tape etc.”
    Brisbane, Australia
