Uncompressed DVCPRO-HD Capture.
These are Varicam / Final Cut Pro questions… hope this forum is ok.
Shot on Varicam 720 24p.
1. So do I capture 60P or 24P ? I think 24 (or 23.98)
2. If I want to capture uncompressed from a DVCPRO-HD deck which codec should I use?
coming out of HD-SDI on deck to Kona 3 and using final cut pro 6.0.1. I was thinking of capturing with Pro Res HQ, but I’m not sure that’s a “capturing codec” or if it’s just a codec that I can apply to a sequence after the footage has been captured.3. If I do capture “truly” uncompressed using one of Kona’s 10 bit codecs then which one should I use? I am thinking that “720p 23.98 10 bit Varicam” (is this correct) ?
4. How much quality difference in between Kona 10bit Uncompressed and Pro Res HQ?
thank you
