Activity Forums Panasonic Cameras Uncompressed capture from Varicam
  • Uncompressed capture from Varicam
    Posted by Wolf Austad on May 10, 2006 at 3:09 am
    Does anyone know of a recording device and/or combination of capture card & software that will allow me to record 10-bit Uncompressed from the HD-SDI out of the Varicam at “off” framerates? (I am most interested in 32fps and 36fps) I know that I could use an AJA or Blackmagic card if I shot at the “standard” frame rates, but upon reading the fine print it looks like I am out of luck if I “overcrank” or “undercrank”.
    Requirements would be that the device can read the VITC/UB flags off the HD-SDI stream (preferably with no TC/U-bit deembedders) and be able to ditch the non-flagged frames upon capture.
    This is for a greenscreen job. I already have a few hundred hours of green/blue screen experience with the Varicam so I think I have a pretty good idea when Uncompressed is needed, and when I can get away with using the camera recorder.
    In advance thanks for any suggestions.
    Cheers,
    Aasulv Wolf Austad, fnf
    Director of Photography
    Los Angeles based
    Gary Adcock replied 20 years, 3 months ago 3 Members · 6 Replies
  • Chris Bell
    May 10, 2006 at 1:06 pm
    D5 would be a good choice. Solid, reliable, established format.
    AJA or Blackmagic both read any frame rate from 1-60. Both can do 4:2:2
    Chris Bell
  • Gary Adcock
    May 10, 2006 at 2:43 pm
    [Wolf Austad] “Requirements would be that the device can read the VITC/UB flags off the HD-SDI stream (preferably with no TC/U-bit deembedders) and be able to ditch the non-flagged frames upon capture.”
    All of the Kona HD cards can do the offspeed capture from a Live Varicam in realtime at 8bit, 10bit or any compressed formats available in FCP with no post processing needed.
    Note that FCP does not accept master Timecode over HD/SDI so you will need to deal with that drawback in a live capture scenario.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Chicago, IL
    gary@studio37.com
  • Wolf Austad
    May 10, 2006 at 4:05 pm
    Thanks for the suggestions. However, I am not entirely sure how that would work. When I read the FAQ at f.ex. AJA’s web site I find the following:
    If you are deliberately over/under cranking the shooting rate in order to get a slow/fast motion effect (for example: shooting a clip at 48 fps with the intent to play it back at 1/2 speed in a 24 fps sequence), then you should use the “AJA Kona2: 720p 59.94 DVCProHD” Easy Setup to capture ALL of the frames (active + duplicates) – then process the resulting clip using the software Frame Rate Converter with a target frame rate of 23.98. The KONA 2 board extracts the VariCam flags from the RP-188 stream during capture and inserts them into the captured DVCProHD stream where the FRC can find them. Note that this ONLY works if you are capturing using DVCProHD compression. The KONA 2 board doesn’t do the slow/fast motion processing – this can only be done by the Frame Rate Converter using the VariCam flag bits inside the DVCProHD-compressed clips.
    Now, even if I use a Sony SRW-1 or a Panasonic D5 deck in 720/59.94, which would be good enough for this job, post would still need to digitize this footage and if they can’t ditch the non-flagged frames without going through the DVCPRO HD codec, then I am back to square one. And also, as far as I know, the Panasonic hardware Frame Rate Converter box also uses the DVCPRO HD codec.
    Am I missing something here?
    Is there a workaround I can recommend for post?
    Los Angeles based
  • Gary Adcock
    May 10, 2006 at 5:39 pm
    [Wolf Austad] “When I read the FAQ at f.ex. AJA’s web site I find the following:”
    Wolf,
    Thats is the Apple recommended way to handle the offspeed footage.
    I have been the post instructor at the “Varicamps” for over a year and I show the uncompressed capture process as part of my demos at every camp, mentioning that it is a possible replacement for the Panasonic hardware FRC. ( which can only handle the compressed format.
    The setting for proper highest quality uncompressed VFR acquisition is “AJA Kona2: 720p 23.98 10bit Varicam”
    [Wolf Austad] “Now, even if I use a Sony SRW-1”
    I am not sure the SR-1 records the flagged frames properly from Varicam.
    [Wolf Austad] “post would still need to digitize this footage and if they can’t ditch the non-flagged frames without going through the DVCPRO HD codec, then I am back to square one.”
    Again it is possible to handle the VFR content directly in FCP at a 10bit Uncompressed rate direct from the camera. Using a Kona 2 board.
    [Wolf Austad] “as far as I know, the Panasonic hardware Frame Rate Converter box also uses the DVCPRO HD codec.”
    That is correct .
    gary adcock
    Studio37
    Chicago, IL
    gary@studio37.com
  • Wolf Austad
    May 11, 2006 at 11:23 pm
    Thank you for a very informative answer! I guess I attended the Varicamp before you started lecturing there… Otherwise I would have known better.
    Now, if this VITC reading problem is located to Final Cut Pro, would I be able to use f.ex. AJA VTR Exchange to capture and by that be able to use just one HD-SDI cable from the camera? Running an extra cable out of the camera for TC is a major PITA for onset work, so I would really like to avoid it.
    Los Angeles based
  • Gary Adcock
    May 12, 2006 at 1:57 pm
    [Wolf Austad] “Now, if this VITC reading problem is located to Final Cut Pro, would I be able to use f.ex. AJA VTR Exchange to capture and by that be able to use just one HD-SDI cable from the camera? Running an extra cable out of the camera for TC is a major PITA for onset work, so I would really like to avoid i”
    Yes AJA VTR app will work as this issue is FCP not the Kona Board.
    I never run the TC from the camera in a live capture situation, I generate timecode from a separate off camera source
    and to all the devices as TC or as an audio track to DV cameras.
    gary adcock
    Studio37
    Chicago, IL
    gary@studio37.com
