Activity Forums Blackmagic Design uncompressed AVI problem in MacOS X 10.5.8
  • uncompressed AVI problem in MacOS X 10.5.8
    Posted by Adrian Finn on February 9, 2011 at 9:56 am
    Hi
    We have a Decklink SP in a MacOS X 10.5.8 system and a Decklink HD Extreme in an Ubuntu 10.10 system both of which are used for SD capture to 8 or 10 bit uncompressed.
    The linux / windows uncompressed AVI’s are described as UYVY by quicktime and show no video in Quicktime / FCP etc
    The only way I’ve been able to make the AVI’s play on MacOS X is to use one of the open source media players which is not great as we need to edit these files.
    My workaround is to open the file in a Hex Editor and change any text UYVY top 2vuy and then resave but this is not really a sustainable solution and seems uncessary given that the files are basically the same, just the description in the file is different!
    Is a fix planned for this or any easier way to ensure captures in Windows / Linux play easily in MacOS X??
    thanks
    adrian
    Kristian Lam replied 15 years, 6 months ago 3 Members · 2 Replies
  • Margus Voll
    February 10, 2011 at 9:24 pm
    10 bit uncompressed worked for me not 8 bit
    Margus
    https://iconstudios.eu
  • Kristian Lam
    February 24, 2011 at 1:07 am
    [adrian finn] “My workaround is to open the file in a Hex Editor and change any text UYVY top 2vuy and then resave but this is not really a sustainable solution and seems uncessary given that the files are basically the same, just the description in the file is different!
    I have an AppleScript that will do a batch convert if you want it. I posted a link to this app some time ago on this forum.
    We’ll have to check if we can capture to the same fourcc as we run the risk of the wrong colorspace being used on Windows should we use 2vuy.
    regards
    Kristian Lam
    Blackmagic Design
