Activity Forums Compression Techniques uncompressed avi or animation quicktime
  • uncompressed avi or animation quicktime
    Posted by Whitlock Dunbar on November 29, 2007 at 2:02 am
    What’s the consensus on the best format to render to on the PC, as an uncompressed .avi file or a quicktime using the animation codec set to best quality. I’ve always created quicktimes but until recently I’ve only used Macs. Or does it even matter?
    Daniel Low replied 18 years, 9 months ago 3 Members · 2 Replies
  • Richard Sanchez
    November 29, 2007 at 2:28 am
    Where are you planning on taking the file once it’s rendered? If you’re bringing it into an Avid, you might want to go with a quicktime file render with an Avid 1:1 or Packed Codec (1:1 10 bit).
    Depending on where you want to do with the video might make a difference which codec will suit you best.
    Richard Sanchez
    North Hollywood, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
  • Daniel Low
    November 29, 2007 at 11:09 am
    The problem with AVI is that it’s just a container for audio and video. It’s not always possible to know exactly what is contained as such it’s not always cross platform.
    The advantage of Quicktime Animation is that it’s a known, it’s 4:4:4, it cross platform and any setup with Quicktime installed will be able to work with the file.
    Animation is only lossless when set to 100%
